Old 06-05-2012, 11:53 AM   #1
Boris the Yaris
Drives: Yaris T3
Dropped Tail Light Bulb and Socket
I wanted to to change the tail light and dropped the socket and bulb down into the well of the car, I can't see the bulb or socket. any ideas?
Boris the Yaris is offline   Reply With Quote
Old 06-05-2012, 12:03 PM   #2
You can either pull the cargo area side cover to get to it, or if you remove the tail light from that side (by removing the two 10mm nuts) you have easier access for getting down to the bulb's location from that side.
Old 06-06-2012, 09:09 PM   #3
thepartsmancometh
Drives: '08 LB, '07 WRX
I dropped a tail light nut once on our hatch; that required removing the spare tire and all trim near it.
thepartsmancometh is offline   Reply With Quote
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
Indicator/Park light Socket jackay DIY / Maintenance / Service 0 04-30-2011 10:15 PM
