Old 10-19-2008, 06:33 AM   #1
goku87
goku87's Avatar
Drives: Black HB
DIY: Yaris LB Halo Led Projector Headlights
This was originally posted in the "Marketplace > Sponsors Classifieds Area > depoautolights" section, but since the hack it is no longer there. im putting it back up because i thought these things looked sick.
JUST TO BE CLEAR, I DIDN'T WRITE THIS, AND I DONT HAVE THESE LIGHTS.
In the original post the vendor (depoautolights) was advertising them at $272 w/ shipping (including canada) however, on their site, it is now $307. I am unsure as to if that includes s&h.
http://depoautolights.com/headlights...be8cd4aa82ba2b
They were also selling tail lights and fog lights, which are available on their site.
Anyway, here is the DIY copied straight from the Google cache:
DIY AND PICS COURTESY OF PETEAUSSI:
Connecting Halos to Parkers.
1. Cut the cable for the LEDs about 4 inches down the wire from the grey socket thingy they go into... This is so you can splice the halo wires into here.. Next you want to strip the wires, on all four of the cut wires, using a wire stripper tool so that about a half inch of the bare wire is exposed. At this point you may want to trim the halo wire as it is unnecessarily long.. Strip it as well so that bare wire is exposed.
2 Once you have the wires stripped (you should have six wires.. two for the halos, two from the leds, and two from the led/ parker socket) you want to get an electrical connector joint, which is blue in my pictures.. I picked mine up from the local hardware store.
3. Next you want to wind the black halo wire around the black LED wire and likewise with the white ones.. This provides the connections.. Next put this now one ended dual wire into the connector with the parker sock wires in the other end of the connector and crimp with pliers..
4. Tug on the connection to make sure both ends of the connector are secure and then wrap in electrical tape to keep dust etc out..
5. You now have halos that will turn on with the LEDS...Tidy up as you want with zip ties or more electrical tape..
Installation of lights on car..
1. Obviously you want to open your hood to get at the lights.. But next you want to take out the little black plastic screw type things.. in total there should be 6 of them.. four on the top.. and one in each wheel well.. You also want to remember to undo the hood pop up device as this also holds the hood down.. Then there are five or so screws under the front bumper which you need to unscrew and keep in a secure place..
2. Next you want to pull the front bumper off... the sides need to be pulled out a little to release them so they can go forward.. I didn't fully take off my bumper... rather just got it so it was leaning forward a bit.. Remember that there are two clips.. one on each side at the bottom of the bumper.. these need to be slid sideways first..
3. Then you need to unscrew the three bolts holding the headlight assembly onto the frame.. there is one at the top, one at the front under where the bumper was, and one on the side where the bumper was..
4. You want to disconnect the light plugs as well. The indictor light you need to twist the white socket and this will remove the whole assembly and bulb, which is to be installed in the new lights later.. You should have to undo three sockets in total... a brown one which is for your parkers, the indictor light, and the main bulb socket. You light should now be able to be removed without any wires connected to it..
5. From the back of the stock light you want to remove the parker assembly as you need this for the new parkers.. then you want to remove the bulb and this is where the new parkers slot into.. Slot the new parkers into where the parker bulb was and connect this to the brown parker socket... connect the main light socket with the three prongs as you normally would do... and then put the indicator assembly into the top hole and twist.. It takes a bit of force but it can be done.
6. Then it is best to turn on your lights to check if they work before screwing everything back together..
7. If everything is fine then just put the light assembly back in by doing up all the bolts half way, push the new light assembly back and tighten the top screw first... this I find gives you the best, but still not perfect, fit.
8 Repeat this with on the other side of the car and then put the bumper back on. You may notice the little black screw type things don't fit as well into the point where the bumper connects to the light... use a zip tie for this connection to make it secure.. Bobs your uncle you now have new lights..
PICTURES OF CUTOFF COURTESY OF PETEAUSSI:
Old 10-19-2008, 08:16 AM   #2
ChinoCharles
Drives: LB
Thank you!!!!!!
Old 10-27-2008, 06:01 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i can watch this over and over again...great diy..
Old 10-28-2008, 01:10 PM   #4
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
What are the Halo bulbs? 194's?
Saggio is offline   Reply With Quote
Old 11-15-2008, 10:49 PM   #5
goku87
goku87's Avatar
Drives: Black HB
Actually, I think they might just be plastic rings with an LED lighting them up. Can't tell for sure. I'll let you know whenever I get them.
Old 11-16-2008, 04:57 AM   #6
mhkritzinger
Drives: 1.8 3dr Yaris TS
hey! awsome thread!! i wuld just like to know my yaris headlights is height ajustable and wondered if that will stil work with the new headlights?
Thanx
mhkritzinger is offline   Reply With Quote
Old 11-16-2008, 10:30 AM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Is there a way to just turn 1 halo on?
Its a Chao!!!
Old 11-16-2008, 10:03 PM   #8
YAR1S
YAR1S's Avatar
mmm I want these for christmas.
Old 11-17-2008, 02:23 PM   #9
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Anyone know if depo is coming back?
cm07yaris is offline   Reply With Quote
Old 11-17-2008, 05:46 PM   #10
dybbuk
dybbuk's Avatar
Drives: 2008 Yaris HB
Anybody ever consider painting all the black to colour-match? Too burned out right now to PS it, but, I think it would look pretty slick.
dybbuk is offline   Reply With Quote
Old 11-20-2008, 01:13 PM   #11
YarisRHC
Drives: Stock standard at the moment..
SWEEEEEET!!!!!
YarisRHC is offline   Reply With Quote
Old 11-20-2008, 09:01 PM   #12
Greytimberwolf68
Greytimberwolf68's Avatar
Drives: 07 abosolute red Yaris
me want!!!!! but i found one for cheaper and they have tail light for the 3 door. I don't know about the sedan. http://www.k2motor.com/06-08-yaris-p...eadlights.html
Greytimberwolf68 is offline   Reply With Quote
Old 06-10-2009, 12:29 AM   #13
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
sexy sexy headlights...
i got them today!! and installed them today!!! I got them on EBAY NEW at a steal price of 220AUD :) Thanks for the DIY just needed help with the wiring! :)
Your the best goku87, i know how hard it is to write a great DIY..
anywhoo anyone with these headlights...umm are the bottom right light suppose to work? Mine isnt turning on! :( -dont worry its the high beams lol
Old 06-18-2009, 02:49 PM   #14
ReeseAnderson
Lucky Number Seven !..
Drives: Toyota Yaris 1.3 VVT-i SR
Never go to get items from Depo Auto Lights, i've had 2 months of hell trying to get the damaged ones they sent to me replaced. Shocking customer service, never gonna use them again.
ReeseAnderson is offline   Reply With Quote
Old 06-18-2009, 02:51 PM   #15
marcus
toyota
marcus's Avatar
awaiting for micro image retro...
Old 10-11-2009, 05:42 PM   #16
weslowski
weslowski's Avatar
Drives: yaris
Smile
just shouuld of stuck some HID lights ligghts than LED
weslowski is offline   Reply With Quote
Old 01-02-2010, 10:20 PM   #17
quimico
Drives: Yaris HB 07
Hey guys, i have the black projector headlamps in my Yaris but i would like to know how change the LED's, i put 4300K HID's and i am not very happy with the contrast between the blue leds and pure-white HID, i would like to get the same color in both.
Anybody knows what kind of LED's i should buy to get that?
quimico is offline   Reply With Quote
Old 04-09-2010, 01:46 PM   #18
Jerkratt
Jerkratt's Avatar
im in the prosses of looking for diff ones there not normal 194's if i find something ill post it here
"It hurts more when its wet"
Poll - LED Eyebrows for the Yaris - Vote Yea or Nay Violin Cosmetic Modifications (Exterior/Interior) 63 04-29-2007 12:26 AM
