play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
will this fit a yaris?
It's for an old Toyota Corolla 1ZZFE 1.8. Would it bolt up to the 1.5?
The really long equal length runners ought to give it a lot of bottom end torque. |
2ZR swap. DO IT! Ask how!
I've got one in the shed, and no, it won't bolt up as-is. The cylinder spacing is too wide, so the ports won't match up. I've got a thread around here somewhere with a schematic...
Here it is: http://www.yarisworld.com/forums/showthread.php?t=39274 Last edited by CrankyOldMan; 05-28-2012 at 07:50 PM. |
play every day
Hey, thanks, for the info, Cranky.
![]() I happened to see one on ebay and really liked the design. No wonder they were so cheap!
^ That intake would also be for a cable throttle body, I think.
play every day
Hey Garm,
![]() It's definitely old enough to fly by cable. I found some more pics and besides the ports not fitting, its throttle body has only three studs. I just thought that design was really intriguing as all the runners point directly at the throttle body with no inline plenum needed. It would flow just like a backwards 4-1 header and eliminate all of the unequal distribution issues of inline runners. By the way, that grey ceramic coated half round plenum header was actually the Weapon R intake. I found some more pics from the backside which showed their half round profile design. |
#6 | |
OK, here's the template for the 4-bolt side: http://www.yarisworld.com/forums/showthread.php?t=36796 And here's the thread where I first saw this mod: http://www.yarisworld.com/forums/showthread.php?t=36723 I made up a model in CAD for the adapter plate but have no idea if the offset will cause issues. Gonna have to get some time this week to convert the part to a drawing. Last edited by CrankyOldMan; 05-29-2012 at 06:28 AM. |
play every day
Wow... so some of you guys have already been down this road.
![]() Cool. ![]() Just picked this one up on ebay for $85 including the shipping. I really like the low end torque design and know a couple of really smart guys who have their own CNC in their garage. Heck, even if it cost $400 to adapt it, I'll still have a really neato intake for under $500. Last edited by tooter; 05-29-2012 at 11:50 AM. |
#8 | |
play every day
Please do! I can even supply you with the CAD files if you're having it CNC'd. The only thing I'm not 100% sure of is the bolt hole placement, and it's missing the gasket channel on the engine side.
#10 | |
play every day
![]() I'm not exactly sure what to do yet, and need to talk with the cnc guys as I know absolutely nothing about how this whole process works. I just ran the electrical feed and wired the sub panel to power their cnc machine. I think the bolt hole spacing can be pinned down using the stock manifold. Possibly the gasket channel too, or maybe I'll just trace and cut out a flat gasket from some stock as the plate will be nice and thick. So the original mounting flange gets cut off and the runners ground to fit into your adaptor and welded up? ![]() When I get the manifold within the week I'll be removing the stock one so as to be able to put the openings side by side. The nicest part is that the manifold design already works. Each end just needs to be adapted to fit the new engine and throttle body. ...and there's this for inspiration... ![]()
Tooter, how are you going to match the flange to a 1.5L head?
play every day
Hey Garm,
![]() Not sure as I haven't even seen it yet, but I'll figure out something. The intake is so dang cheap to begin with, I can afford to go first class on the adaptation. Aluminium cuts and welds easily and the manifold itself is a great start with Toyota's flow engineering having already been designed into it. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
I'd like to do that mods too :O
Does is need a cable throttle body ? SO tooter you will use the stock one with the 1zz one ? to make it fit ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#14 |
play every day
I'm going to use the stock fly by wire throttle body to minimise having to change out any other components. It will likely be an adaptor plate that bolts onto the Corolla manifold's three threaded holes, and has the proper threaded stud holes to accept the 4 studs that will match the stock throttle body.
#15 |
Post pictures of you do :) I want to see....mauybe ill do the same :D
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
| Can a Yaris fit 13" wheels?? | MrWideTires | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 34 | 10-15-2009 12:16 AM |
| What aftermarket exhaust will fit the Yaris Sedan? | dngz | Performance Modifications | 2 | 10-02-2006 01:41 PM |
