Old 10-04-2009, 09:33 PM   #1
MrWideTires
Drives: 04 SE-R
Can a Yaris fit 13" wheels??
I'm looking into getting a Yaris.. but I'd love to fit some 205/60-13s.. can these cars fit 13" wheels??
MrWideTires is offline   Reply With Quote
Old 10-04-2009, 10:58 PM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
I believe this has been covered but I can't find the thread. I also believe the smallest we can fit is 14"
RacerFreakXXX is offline   Reply With Quote
Old 10-04-2009, 11:05 PM   #3
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Why?
RUFFSTUFF is offline   Reply With Quote
Old 10-04-2009, 11:54 PM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yes, the yaris can rock 13's
Do a search for lenso vpd and you'll see
Old 10-05-2009, 12:10 AM   #5
AND189
Drives: 2
i have some 13" but never fitted them ... found them on the side of the road
AND189 is offline   Reply With Quote
Old 10-05-2009, 06:59 AM   #6
mojoyaris has 13"x7.5" Lenso VPD wheels, silver and gold on Toyo R888 GG comp 225x45x13
Old 10-05-2009, 12:37 PM   #7
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Originally Posted by RUFFSTUFF View Post
Why?
Smaller wheels/tires=less rotating mass. Lighter=faster acceleration.
Old 10-05-2009, 03:37 PM   #8
RUFFSTUFF
Nothing like buying a Yaris and then spending money to try to keep up with Corrollas...
The unsprung weight loss of the smaller wheel may (assuming wheel characteristics are the same i.e. not going from 15" alloy to 13" steel) improve handling characteristics, but is there much in the area of straight line performance gain? Except if you don't adjust the aspect ratio for the minus-2 sizing, then you will have higher gearing which will improve acceleration at the cost of top speed. Running a higher aspect ratio tire to compensate for the smaller wheel is sure to hurt cornering performance... as the tire shifts off-axis with the wheel.
Old 10-05-2009, 03:43 PM   #9
CASTREX
CASTREX's Avatar
Actually cornering is improved.
Removal of unsprung weight not only improve straight line acceleration, but also overall handling and breaking.
And what are you talking about keeping up with a Corolla? A Corolla can't keep up with a Yaris... not even in it's dreams...
Old 10-05-2009, 03:45 PM   #10
RUFFSTUFF
Removal of sprung weight not only improve straight line acceleration, but also overall handling and breaking.
Wheels are unsprung weight. Anything the weighs down the suspension is sprung.
Yaris vs. Corolla... Fight!
Old 10-05-2009, 04:00 PM   #11
CASTREX
CASTREX's Avatar
Yeah... edited. You got the point though.
Any way... the Yaris reacts very well to wheel/tire weight reduction.
Also a good point on the positive side of shortening the gearing. Not a good idea for a DD, but the Yaris would benefit of a shorter ratio for the track or autoX
Old 10-05-2009, 04:25 PM   #12
RUFFSTUFF
Neat.
Old 10-05-2009, 04:38 PM   #13
if you run anything other than rcomps on the 13's or 14's, i find the steering is squirmy at the limits due to sidewall flex.
i had 14" steelies w/ fuzion hri's (185-60-14) and on hard cornering you could feel the tires squirming around...
Old 10-05-2009, 04:47 PM   #14
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
what psi were you running? 32, max side wall (if so... what?)... psi adjustments might be able to make up for the issues you had.
Old 10-05-2009, 05:07 PM   #15
for DD i was at 35psi
auto-x i was 40
its a lot of rubber to not flex when you have all seasons
Old 10-05-2009, 05:16 PM   #16
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
are you saying aftermarket rims/tires, if not adjusted to correct size, causes loss in top speed?
Its a Chao!!!
Old 10-05-2009, 05:59 PM   #17
CASTREX
CASTREX's Avatar
I think he was just going by the general rule of thumb.
Shorter ratios foe better acceleration and longer ratios for higher max speed... although is not as simple as that....
Old 10-05-2009, 06:44 PM   #18
RUFFSTUFF
Actually it is. If you change nothing but the diameter of the wheel and tire, acceleration and top speed will change accordingly. And oh yeah, your speedometer accuracy will also be affected. The diameter of your wheel and tire is based on the rim size, the tire width and the aspect ratio. This overall diameter multiplied by pi will give you an approximate rolling circumference. I say approximate because without taking a physical measurement, you're left with the manufacturer's size rating and they are not very good at providing good measurements. Tires labeled as the same size can actually be quite different, even within the same manufacturer. On my Mazda3sGT, I went from a 205/45-17 OEM to a 205/40-17 Fuzion tire. It was a noticeable change in acceleration (quickness). Top speed originally was limited to 114mph on the speedo (112mph GPS)... the rev limiter still kicks in at 114mph on the speedo, except that it is now only 105mph on the GPS. Keep in mind that speedos do not report actual speed, much like gas gauges don't report actual fuel level... only different. :)
Factory Miata wheels fit without modification? evan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-02-2015 08:01 PM
Black Yaris.. What wheels? buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-11-2009 06:03 PM
