My car has 91000 and I want to make it last. I don't rack on miles like I did when I bought it. I think I did 30k + my first year. Anyways I read a few other posts but every time I read them they said the car was new, or they had some old ass car and ruined the seals after the switch. The yaris motor is a lot different than 90's cars. Just want to know if it's ok to switch. Thanks
![]() ![]() Drives: 2009 yaris 4dr hb Join Date: May 2010
I made my switch on my 04 corolla with 100k! and no leak! and it seems to run and start smoother when i did the switch. I made my switch for my yaris at 40k and also no problem
Not quite a noob
The synthetic doesn't ruin the seals, the seal had gaps in them because they were old. Synthetic is less viscous than regular oil, and thus can leak out of these tiny holes that conventional oil usually can't.
So should I make the switch or not? I want to get the most out of this car. Thanks for your input so far guys.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
http://www.mobiloil.com/USA-English/...ics/Myths.aspx
Mobil says it's OK. Why not try some Mobil1 High Mileage? |
The Beautification of Car
with all these Free after rebate for Synthetic, why not? :)
The Beautification Of Car Enthusiast |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2012
Shouldn't be a problem, I put synthetic in mine after 86k miles. And IMO, runs soo much smoother
Won't hurt a thing . The synthetic does quiet the engine a bit .
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
should'nt be a issue I've ran sythetic since new
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
So do you guys recommend a certain oil filter if I use mobile 1 synthetic?
If you aren't going to run a long oil change interval, any of the major brands would work. If I could only ever get one filter, I'd probably just buy a Bosch 3311. It's nearly identical to the Purolator Pure One without the yellow paint job. If I had to buy what they sold at Wal-Mart, I'd have no problem with the Fram Toughguard.
Mobil 1 has their own filters, I've heard good things about K&N, Purolators, Wix, Napa (Which I think is also made by Wix). Just use whatever you can find, except the cardboard crap.... (FRAM....)
i use a NAPA filter
![]() ![]() Drives: 07 BB yaris / 06 Mustang Gt Join Date: Apr 2007
walmart sells purolater for $3.50 i think :) i wouldn't recommend on very old car though, i used on 89 chevy van check engine came on after few hundred miles.. it has around 110k miles on it. but 100k on newer car should be fine
I was gonna do 10k intervals. I think I'll go with the bosch one. Is that a good pick?
#16 | |
http://www.boschautoparts.com/filter...ilFilters.aspx |
#17 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| The switch to synthetic | Captain Slow | DIY / Maintenance / Service | 9 | 04-15-2012 01:02 AM |
| BJs Wholesale : SHELL conventional or synthetic $9 off a case ... | Hershey | DIY / Maintenance / Service | 1 | 01-24-2012 11:42 PM |
| Can I switch to synthetic after my first 8000km oil change?? | Moore | General Yaris / Vitz Discussion | 28 | 08-11-2007 12:29 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
