Old 06-10-2007, 02:25 AM   #1
Moore
Moore's Avatar
Drives: 2007 yaris 3dr ce
Can I switch to synthetic after my first 8000km oil change??
Is that too soon? I have heard and read that I should wait until atleast 30,000kms to let the everything set properly.
Moore is offline   Reply With Quote
Old 06-10-2007, 02:49 AM   #2
i switched at close to 7k miles. i think you'll get different responses here tho.
Old 06-10-2007, 09:14 AM   #3
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
A lot of cars come from the factory with synthetic.
blacksan is offline   Reply With Quote
Old 06-10-2007, 09:34 AM   #4
Yaris_Fan
Yaris_Fan's Avatar
Drives: Liftback Auto
Yes, but many of those high performance cars go through hours of testing at the factory. Essentially they're broken in when they are delivered new.
Yaris_Fan is offline   Reply With Quote
Old 06-10-2007, 09:36 AM   #5
blacksan
blacksan's Avatar
I very much doubt they do more then drive a new Vette very far from assembly to customer delivery. Stop by the local Chevy dealer and look at an odometer.
Old 06-10-2007, 10:45 AM   #6
I switched at 2,000km
Not sure if it's a direct effect, but mileage had a big boost, engine smoothness too...
Old 06-10-2007, 11:06 AM   #7
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I made Toyota change to synthetic before I drove off the lot . They tried to tell me that the oil would be fine for 3000 miles . I quickly reminded them of who was the cash paying customer .
Old 06-10-2007, 12:20 PM   #8
foober
Drives: two yaris liftbacks
I put in amsoil 0-30 at 3,000. I don't know if my car is just a well made yaris or what. But it has so much zip to it that I'm always having to purposely try and slow down. It just wants to go fast. Speed limits are dangerous for this car.
This lucas fuel treatment seems to work. YOu might try it.http://lucasoil.hodgsoncorp.com/cata...products_id=40
foober is offline   Reply With Quote
Old 06-10-2007, 03:18 PM   #9
Moore
Moore's Avatar
Thanks, I think I'm going to switch around 3000-4000km's.
Old 06-10-2007, 03:53 PM   #10
hans_fh
Just go for it:)
GOOD LUCK
hans_fh is offline   Reply With Quote
Old 06-12-2007, 04:08 PM   #11
Ogredude
Ogredude's Avatar
Drives: 2007 Red Yaris RS
Frickin just DOIT i did at 4000km
Every synthetic website lists 'synthetic Myths' and how any car today is so tight they barley need a breakin
They factory fill cars with synthetic
I think it only applies to older cars from the 70's when they actually used 'break-in-oil' from the factory and all those myths carried over into the 90's and 2000's cars
Ogredude is offline   Reply With Quote
Old 08-09-2007, 07:22 AM   #12
r300f28
Drives: 2007 Yaris Sedan
Switched to Amsoil 5W-30 Synthetic & EAO09 filter at 1017 miles. Engine runs smooth a silk, and mileage went up almost 4 miles per gallon more.
Will do the transmission next & the rear end later down the road.
r300f28 is offline   Reply With Quote
Old 08-09-2007, 11:05 AM   #13
Indianspringsaz
Drives: 07 Bitchin Blue HB
Old wives tale. Do it whenever you want. Many cars come from the factory with it in the car.
Indianspringsaz is offline   Reply With Quote
Old 08-09-2007, 06:52 PM   #14
Thotprawsis
Drives: '07 Blazin' Blue LB
Did mine @ 2500 miles. Seems to run smoother. I don't know if there was an increase in mpg yet. Just go for it!
Thotprawsis is offline   Reply With Quote
Old 08-09-2007, 10:51 PM   #15
Pavel Olavich
Drives: 2007 Yaris LB
Putting synthetic in a car with less then 1,000 will make it blow up, cause massive burns to the occupants, mar, scratch, and incinerate the cylinders beyoud repair, often doing this will cause a piston to explode up, out of the engine, smashing through the little Yaris hood, often causing the driver to wreck his car.... DON'T DO IT!
Pavel Olavich is offline   Reply With Quote
Old 08-09-2007, 11:02 PM   #16
Thotprawsis
Really
Old 08-10-2007, 11:37 AM   #17
aaaah so that piston hit you in the head, explains a lot
Old 08-10-2007, 12:16 PM   #18
Black Yaris
der Zeck
Black Yaris's Avatar
2.2 ecotech is a high preformance motor?
it comes with mobile 1 full synth from the factory...0 miles
so there goes the break in, and high preformance motor theory
I dumped my dino oil as soon as I could, can't remember the exact mileage, but it was under 1000
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 08:15 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
