Old 01-20-2007, 02:13 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
15" Konig Heliums+tire weight info
Some more yaris related information in case anyone cares...
I just fit my new 15" Konig Helium rims with a set of super cool tires.
Hankook R-s2 W212 205/50ZR15 (treadwear 200).
The rims weight 11.8lbs.
The rim + tire weights 31.68 lbs
If I compare this with the 33lbs OEM alloys I just JUST reduce 1.3lbs (sucks... you might say) but in the other hand I´m going to be running on a much wider and super grippy tire so I´m quite happy with the result.
Some thing else. This size of tire is a little bit to wide for the heliums... so if you have those rims... you should probably go with 195 instead of 205.
CASTREX is offline
Old 01-20-2007, 02:26 PM   #2
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
sweet i plan on buying a set of silver heliums do u have any pics?
My Car
My Garage
BokChoi is offline
Old 01-20-2007, 02:37 PM   #3
CASTREX
CASTREX's Avatar
Post some pics later... my camera has no batteries
CASTREX is offline
Old 01-20-2007, 07:41 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
what is the width on the heliums? I am running a 15x7 with a 225/50 and she looks fine, maybe a tad wide, but I love the handling with the 225's
Black Yaris is offline
Old 01-21-2007, 01:23 PM   #5
CASTREX
CASTREX's Avatar
The heliums are 6.5" wide.
It's weird because 205 tires should be a perfect match for this size of rim. I dunno if it has to do annything with the tires being ZR or something like that. I tought 205 will always be 205 no matter the brand or kind of tire you are using.
Please correct me if I'm wrong.
CASTREX is offline
Old 02-21-2007, 01:29 PM   #6
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
The reason is simple. Race tires like the Hankook 212's or Falken Azenis run REALLY wide. Technically yes, a 205 tire should be ok on a 7" wide wheel, but I come from the BMW camp, where you run the BEST size for that width of wheel. Examples:
8'5" wheel 245/255 max
8" wheel 235
7.5" wheel 215/225 max
7" wheel 205
6.5" wheel 195
6" wheel 185
etc etc
Problem is you have every mustang/camaro owner telling you.."Dude I run 275 Nitto's with 8" wide wheels and it's fine." And in reality his car handles like crap (Not that domestic owners care).
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline
Old 02-22-2007, 06:19 PM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
8" wheel 235
7" wheel 205
6.5" wheel 195
6" wheel 185
etc etc
Thats not 100% correct. Each tire manufacturer measures width a bit different. A 315 Nitto is as wide as a 295 BFG,Goodyear or Kumho tire. There is no real measurment standard. Your "best sizing" list is fine for certain cases, but for AWD cars, or heavier cars you will be better off going a bit wider as long as you have the correct offset and clearance.
Too narrow or too wide of a tire on a given rim is not good for handling. I would rather be on the wide side than the narrow side. The streched sidewall deal that people like right now is horrible for handling.
Ashley
largeorangefont is offline
Old 02-22-2007, 06:41 PM   #8
OK Yaris
Drives: 2007 Liftback
Just for reference, here's some photos of my Yaris with stock Bridgestones
(185/60R15) on 15" Heliums. I might go a little wider after I wear out these tires..............Mike
OK Yaris is offline
Old 02-22-2007, 08:54 PM   #9
Nimble
Ashley
That's also not 100% correct. Too narrow (within reason) will almost always perform better than too wide. A 275 on a 8" wheel will deflect a lot in turns, whereas a 225, a bit too narrow won't budge in a turn.
While I see that you like to try and correct me. I have owned and raced 7 BMW's and a few were ///M cars, I understand handling and tires more than I could type in a paragraph. I used to do the rolling diameter calculations just for the heck of it with the formula memorized. Sure a 245 Kumho MX or Bridgestone S-03 will run wider than say a Dunlop SP Sport 9000 or Kumho Exsta Supra 712, but my above recommendations are damn close to spot on.
I realize you're a domestic owner at heart, and I...well...hate the damn cars, barring the Vettes, a car that can actually perform ALL AROUND well, and not be built like poo. But there's no need to argue with me on common sense things. A 245 tire will always perform better than a 265 on a 8" wheel, it fits the wheel correctly giving more precise handling. And no, I don't run euro stretched tires, just CORRECT for the wheel, that's all.
Nimble is offline
Old 02-23-2007, 01:03 PM   #10
Nimble
Ashley
I felt the need to quote you to make you look like a tool, ASHLEY.
Here's what you quoted of me, but yet your second sentence sure doesn't make ANY sense when looking at what I typed. Retard.
8" wheel 235
7" wheel 205
6.5" wheel 195
6" wheel 185
etc etc
Nimble is offline
Old 02-22-2007, 07:52 AM   #11
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
actual section width is based on wheel width and the tire itself (should be consistent through out the model in a given size).
go on tire rack and look up the "specs" of some tires you'll see the differences, it is more dependent on the "style" (max performance vs. all seasons) then it is speed rating (although most max performance tires have a higher speed rating).
and the # posted on the tire is rarely "exactly" what the actual tire you have on your wheel is.
Russelt3hPirate is offline
Old 01-21-2007, 07:17 PM   #12
Black Yaris
der Zeck
205 is shoulder to shoulder (the shoulder starts where the smooth side wall ends) not the footprint of the tire. Perfect example my tires are 225/50VR15 g-force sports, my wife's tires are 225/50HR16 Potenza G009's my tires actually have a wider footprint than hers for 2 reasons (1)brand/model & (2) speed rating. I mean you could take the same tire I have and a BFG traction TA same speed rating and size, There still will be a bit of difference in the footprint, it is all in how the tire is designed.
Old 01-21-2007, 10:03 PM   #13
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
This surprises me as I thought the oem alloy would be lighter. My stock steel wheels and tires weigh 33 lbs(w/o covers). But you did get a wider tire and save weight so thats sweet.
PetersRedYaris is offline
Old 02-21-2007, 11:50 PM   #14
fazali
fazali's Avatar
Drives: 2007 Toyota Yaris LB
should have got the Feathers
Dallas, TX
2007 Yaris HB
Polar White
15" Black Feather Konig's
Viper Remote Start Alarm System
20% Window Tint All Around
fazali is offline
Old 02-22-2007, 06:00 PM   #15
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Anyone know what the stock 14" steelies with tires weigh?? I want to get the 16" Feathers on 195 Azenis'
jdubau55 is offline
Old 02-22-2007, 09:06 PM   #16
magoo_lc1
Drives: honda civic hatch
It looks nice but from the pics it dont look lower to me so it makes the rims look like a very nice stock upgrade.
91 SE-R. R.I.P old freind
The influence of peers on individual behavior illustrates the seductive power of conformity
And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at
magoo_lc1 is offline
Old 02-22-2007, 09:25 PM   #17
OK Yaris
You are correct. The car is not lowered, yet. I'd like to lower it, but it snows once in awhile and the roads aren't super smooth here. Plus, there's always plenty of roadkill to avoid, and some of the roadkill can be pretty large
OK Yaris is offline
Old 02-22-2007, 10:57 PM   #18
Nimble
Thing is, I'm not wrong. And any time you've debated with me, you've been wrong. Keep up the trend.
Tell me, what am I wrong about, that hicks like you run 315 drag radials on 9" wide wheels and street tires up front. Safe huh? Tell you what, my BMW days were in a land where handling dynamics rein supreme. I'll take that vs a AWD Subaru or Mustang owner's views any day.
P.S. I can drive
Nimble is offline
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Stock 15" RS 5 Spoke Rim weight? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-03-2006 05:23 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 06:00 AM
