![]() ![]() Drives: 2010 Yaris Sedan 4-DR Join Date: Apr 2012
Question about suspension / steering
Hello
I have a weird issue going on. When I reverse out of a parking space or other stop, there is a strange 'wobble' coming from the front two wheels. It feels almost as if the car is losing it's footing. It doesn't happen all the time, only on occasion, and only when I'm slowly reversing out of a spot. I have read online that this can be attributed to any number of things, including bad wheel bearings, bad alignment, and other suspension problems. I was just curious if anyone else has had similar issues, or if anyone had any ideas or suggestions in regards to my situation. Thanks, -zkay Last edited by zkay; 07-08-2012 at 04:13 PM. |
Anybody? I should also mention that my car is fairly new (17k miles) and had an alignment pretty recently at 12k miles, I believe (will double check). I don't drive it rough, although I did cross some train tracks pretty recently hard enough that the TRAC/stability control started going off and beeping.
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
Have you checked to make sure they tightened all the bolts when they did your alignment? Why an alignment so soon? You hit something?
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#4 | |
I didn't check the bolts, I will do that and check back in. |
Depot Damager
I believe the next check would be to jack up each side of the front of the car and try to wiggle the rim. Grab each side of the tire and pull one side and push the other. Similar to this video.
Also check to see if your lugnuts are tight.
#6 | |
Just weird. I will check to see if either rim wiggles in the next few days and report back. Thank you for your help! -zkay |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
How much of a wobble is it? Does the steering wheel move with the wobble? Where do you feel the wobble? Seat, feet, steering wheel etc.
#8 | |
But, not being able to reproduce it at all yesterday has me stumped. |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Manual or automatic?
Automatic. Yesterday I had to stop at the post office here in town and in order to go about my day I had to make a u-turn with the wheel locked out all the way to the left from a dead stop. It didn't do the wobble.
It also didn't do it at any other point in my day, at any of my other stops. At this point, I'm just going to call the problem a ghost until it starts occurring with some kind of regularity. Thanks for the help, guys. I do appreciate it. -zkay |
| Steering Wheel question | heeroyuy01195 | Cosmetic Modifications (Exterior/Interior) | 33 | 03-07-2012 02:27 AM |
| Black/Grey OEM Leather Steering wheel question | heeroyuy01195 | Cosmetic Modifications (Exterior/Interior) | 12 | 10-14-2011 02:22 AM |
| Noobie suspension question?? | Richie76 | Australia | 6 | 12-27-2009 10:27 PM |
| Steering & Suspension Problem?! | Trilixia | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 05-20-2009 11:15 AM |
| Technical Question for the Suspension Gurus | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-22-2007 12:31 AM |
