Old 10-03-2011, 11:22 AM   #1
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Black/Grey OEM Leather Steering wheel question
Hey everyone,
I'm about to buy the black and grey leather steering wheel that toyota offered as an option for the Scion Xb and Xd but I want to confirm that I have the correct part number and if it even fits the Yaris.
I have the PN: 08460-12820
Can anyone confirm that this is the correct part number and if it will fit the Yaris? Thanks in advanced.
heeroyuy01195 is offline   Reply With Quote
Old 10-03-2011, 12:05 PM   #2
That part number is correct and will fit the Yaris. You will have to remove the Audio controls (if they come with it), in order to mount your Yaris aribag.
Old 10-03-2011, 05:19 PM   #3
heeroyuy01195
Thanks Scott, always a life saver!
Old 10-03-2011, 07:47 PM   #4
Klink10
Klink10's Avatar
If you want to see what it looks like mounted, ck my garage.
Old 10-03-2011, 09:52 PM   #5
heeroyuy01195
Thanks Klink, your car's even the same colour as mine lol. Looks like it matches the silver center console perfectly
Old 10-04-2011, 06:04 AM   #6
Klink10
Klink10's Avatar
It does. One reason I haven't painted any pieces in there. By the way the swap took about 30 minutes. Remember to undo the negative battery terminal and let it sit for a few and check the DIY out real good so you know which wires to play with.
Old 10-11-2011, 02:00 AM   #7
heeroyuy01195
Thanks for the tips, I figured I'd have to disconnect the battery. Never swapped a steering wheel on a car with an airbag before so I'm not really looking forward to the swap lol.
Old 10-11-2011, 06:15 AM   #8
Klink10
Klink10's Avatar
Easy to do, took me 30 minutes but I have lots of tools and the correct ones needed. We used to have a DIY here with pics. Don't know what happened to it.
Old 10-11-2011, 07:00 AM   #9
My cruise control DIY explains removing the airbag and the steering wheel:
http://www.yarisworld.com/forums/sho...ruise+diy+2011
And, here's a video I had put together on how to remove the clockspring. It is going a step farther than removing the wheel, but it does show how to remove it:
http://www.youtube.com/watch?v=LgWSzVeILhc
Old 10-11-2011, 08:35 PM   #10
heeroyuy01195
Thanks for the tips everyone. I have the tools and such to do the job, just not used to working on modern cars with airbags as all of my project cars have been from the 80's. Does the airbag stay active after disconnected from the battery?
Old 10-11-2011, 08:47 PM   #11
The airbag is a bomb that requires power to make it pop. once you pull the connector it is disarmed, but since it is an explosive charge, you should always handle it as such. The service manual says to always set one down with the mount down. That way if for some reason it goes off is won't launch.
Old 10-11-2011, 09:08 PM   #12
Klink10
Klink10's Avatar
Thanks CT for posting those links here.
Old 10-14-2011, 01:22 AM   #13
heeroyuy01195
Thanks for the help and the links Scott, I just placed the order for the steering wheel.
Steering wheel adapter for TS sadha Yaris TS Talk 4 07-14-2010 09:32 AM
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 05:53 AM
Kustom Play's OG Pink Steering Wheel OMG WOWZ HI2U kustom play Items for Sale by private party 8 02-11-2010 09:25 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
