![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
15x7 30+ offset 205/50 tires will it rub in rear
Sorry to ask such a general question...have an opportunity to get a set of kosei 15x7 30 offset wheels for cheap and swap over my 205/50 tires my car is basically slammed will this rub in the rear?
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
im sure you'll be fine. many people get +40offset with 10mm penguin spacers without issue. I had an effective +27 offset 16x7 on 195/50/16 tires with tuck and had no issues at all...even with our crooked rear axle beam.
Form>Function
That is super subtle not aggressive at all. You should be fine
Any updated pics since you've gone lower? |
using 150mm megan rear spring chppped rear shock bolt by a good 1.5 inches..The trick to lowering these more was to reuse the oem upper spring seat and lose the spring perches
BEFORE
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 06:21 PM. |
After:
Diched the rear spring perches, reused oem upper top hat lowered it by an extra 1inch, once this settles it will be highly tucked, though I am dissapointed with the free travel of the megan yaris shock..I am looking into the Function and Form or D2 offering for the 07 Honda Fit as they are shorter by a good 20mm than the yaris
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 06:22 PM. |
Running 2 sets of oem toyota camber bolts in the front (2 camber bolts per wheel) I would conservitively put this at -3..no more fender liner issues..May slot the strut holes if I ever man up and get the TR Motorsport 15x9 36+ offset wheels
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 06:28 PM. |
A trip down memory lane....my old ep3 running -5 camber with buddy club coilovers, J'sRacing DC5 tie rod ends, full hfp kit with 03 tailight swap, k20a swap..A top knotch car with top knotch memories
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 06:07 PM. |
I miss my ep3 but the vitz is growing on me just wish you could use camber plates and lose the crap torsion beam
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 05:52 PM. |
RIms for sale $300 pick up
Mugen wing, with stock 04 tailights..1 month after I got her on Progress Coilovers, a good coilover sadly no camber plates
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 06:31 PM. |
my old 07 yaris with Type S front lip, on tein basics, not a good coilover imo, these are maxed and still not low and too softly valved/sprung
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 Last edited by DeathBeard; 02-10-2013 at 06:24 PM. |
Form>Function
Nice cars lol I still use my 130mm rears springs with the shocks set longer and no issues
Mr. Clean
My car with 15x7+25mm wheels and 205/50/15's:
![]() No rubbing issues. Could still go a little lower also. I did pull and roll my fenders far enough to clear 225/45/15 tires on the same wheels. |
Lol I know you run your springs like that 1.5 but I am unsettled about it for some reason..
tougeghost awesome man
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Am i correct in gathering that 205/50/15s wont be a problem for a car that is lowered 1.8 inches?
and is there a preferred offset range to use?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| What will it take to make 15x7 +27 offset wheels fit Yaris? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 11-28-2010 03:32 AM |
| Rotated tires and adjusted rear brakes today PICS | auxmike | DIY / Maintenance / Service | 11 | 11-14-2008 09:24 AM |
