Old 11-26-2010, 10:32 PM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
What will it take to make 15x7 +27 offset wheels fit Yaris?
I'm still deciding between the Kreuzers and the RPF1's. Thye only problem is that I can get a better deal on the Kreuzers, but it looks like there is gonna be alot of modding involved. The most I've ever done is had -camber to make certain setups work(205/55 on a 15x6 +40 wheel and a 195/55 on a 15x7 +40 wheel). I just wan't to know if it's worth pulling and rolling fenders and adding camber worth all the trouble just to get some wheels to fit?
marlondog is offline   Reply With Quote
Old 11-27-2010, 07:12 AM   #2
ddongbap
FYI, 195s on a x7 with a +40 on a 15 inch rim is super conservative, imo. I think if you can put 195s on a +27, you should be ok.
You gotta do RPF-1s though.
Old 11-27-2010, 07:45 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
15X7 +27 really isn't that gruesome..
Old 11-27-2010, 06:25 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
15x7, ET27, with 195's or 205's will result in significant poke up front, which apparently is quite acceptable to some members.
Old 11-28-2010, 01:18 AM   #5
llewellyn
Drives: 04 Echo
I have an '04 Hatch with XXR 522s, 16 x 7 ET 25, w/ 195 50 r16 tires. The fronts poke a touch, and the rears are pretty close to flush with the fenders. They rub hard in the back if there's anyone back there, but by myself it only rubs if I hit a hard bump. I bought coil spring boosters, and that helped a lot. Also, I'm on stock suspension.
http://www.microimageonline.com/foru...ight=llewellyn
llewellyn is offline   Reply With Quote
Old 11-28-2010, 02:00 AM   #6
ddongbap
Diff pokes for diff folks.
Old 11-28-2010, 02:32 AM   #7
My rear is effectively +28, 17x7.5". It's right at the fender, I had to roll my rear fender so it wouldn't rub too much. Didn't add any negative camber tho.
