![]() ![]() Drives: 2011 Yaris sedan Join Date: Mar 2012
Jack stand locations
Hello all. First off i wanted to say ive done a little bit of research before i posted this thread i just wanted a little bit of clarification.
I have found a few diagrams of where to place a jack. (center of car front is what looks like the K-member. in the rear there is a steel extension that comes down from the center just forward of the rear bumper. My question tho is about where to support the car on stands while working on it. I have always seen people recomending using stands and supporting from the pinch welds. Ive never felt ok working on a car supported by this. But ive also seen people using axle stands with a hockey puck and a grove cut down the center. My question is tho. Does the car do ok being supported by these? do they eventually give up and fold over? where do you get jack stands with a large enough area on top for the hockey puck? my current set of jack stands are just the little top area for using on an axle. Thanks Sean Scott |
EcoFriendly
Drives: 2007 Vitz HB Join Date: Sep 2012
Hi Sean -
Here is what the owner manual says to position the jack/jack stands.
Thanks i appreciate that. It confirms what I thought. does it make any difference that mine is the 2011 sedan? looks pretty standard acrost the board for most yaris regardless of year or body style.
Im still looking for some jack stands with big top sections. also if i want to get the entire car up in the air will it matter if i jack the front or back first? Thanks. Sean Scott |
| Rear point jack issue | bikegerm | General Yaris / Vitz Discussion | 11 | 09-25-2024 03:55 AM |
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 06:33 AM |
| jack stand hockey puck vs wood and wood ramps | jstantherprsn | DIY / Maintenance / Service | 2 | 12-29-2010 08:21 PM |
| Selling winter tires and low profile floor jack with 2 stands | voodoo22 | Canada | 10 | 11-16-2009 10:12 PM |
| Coud someone post pictures of the jack points on the Sedan & Hatch | voodoo22 | DIY / Maintenance / Service | 4 | 11-08-2008 09:24 AM |
