AKA Samurai Racer
De-cat exhaust system
Hi guys , has anybody had a de-cat done on their yaris , if so have you had any problems? any info will help as i want to de-cat my 1.3.
Thanks |
Chode
Drives: Silver 5 Door YRX 1.5L I4 Join Date: Feb 2007
i know a friend who de-catted their RX-7. Here (and probably in most parts of the world) it is illegal to remove the cat, as it removes most of the toxic gasses from the exhaust. (im pretty sure you can take it off for show cars/race cars). You will get a significant HP increase, but it is easy to notice if you have it off because if you rev it, flames might start coming out (and not just the occasional small one, i mean FULL ON) and your eyes start watering if your in a confined space/revving it up at the lights (but mainly for the people behind you)
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2007
Remember that our stock engines were designed to operate with a certain amount of back pressure, taking the cat off some stock engines will cause premature valve seal failure, it's not worth the gain, and besides it will kill your lower end.
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
As Capagotks mentioned, the catalytic converter is there to greatly lessen your vehicle's emissions. If you remove it you will be dumping a lot of noxious emissions straight into your local atmosphere.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
AKA Samurai Racer
thanks for all the advice guys , i really appreciate it!
#6 | |
![]() ![]() Drives: Yaris 3 Door, 04 WRX, 69 Lotus Join Date: Apr 2007
OBDII cars (every car made post-1996) have 2 O2 sensors, one before and one after the cat to verify cat performance. Remove or gut the cat, you'll get a check engine light.
A high flow cat flows just as much as a straight pipe, doesn't give the CE light, and will pass a sniffer test. There is other issues with gutting a cat, including turbulance and killing yourself slowly with the nasty crap that goes into a cat. Quote:
Scooby's do it too, cause they are a boxer. Especially bouncing off the rev limiter. Most other cars it takes something wrong with them to do it. |
Chode
speaking of rotaries, do you think onw would fit in a yaris, mounted sideways, and even if the front bumper had to be extended?
#8 | |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
It's scary to think that half the people surrounding you are below average...
#9 | |
But there was a FWD rotary. A crappy NSU, the Ro 80. The engines were crap - needed rebuilds at 30k, and all the cars came with an auto. You could adapt a FWD tranny to a Rotary, but it'll be pricy. Then there was the Norton Commander and the Suzuki RE5 - Rotary powered motorcycles. Those would definatly fit :D There are ways to adapt them to power a car FWD, but the Suzuki was only a 500cc making 60hp... It'd be alot lighter, but it would be hard to get over 120hp out of it. lol |
Chode
what about a Suzuki GSX1300R (Hayabusa) engine? its not a rotary, but produces 129kw (175 HP) and its only 1299 cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC. (from wikipedia), so I reckon it would easily fit in the yaris, and the 2008 model is bigger with 1340 cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC and a compression ratio of 12.5:1 (up from 11:1). Then turbo it. then you've got yourself a deathtrap on wheels.
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
Some guy in my town had put one in a 99 tercel and kept it front wheel drive. They made a plate for the tranny to use the toyota one. I know they had issues with the intake side of the engine. It was carburated, but now the car is full track car and made rear wheel drive and of course still rotary powered. BTW don't remember if it was 12a or 13b
#12 | |
I put a 13b ported and blown, into a 71 morris mini. With close to 300 hp, that mini was a real beast. |
der Zeck
only thing that is still stock on my exhaust is my cats, and only the cats... everything b4 and after has been opened up to larger diameter pipe.... and no CEL's
Chode
or even better, the Kawasaki Ninja ZX-14, with 1,352 cc Liquid-cooled, 4-stroke In-Line Four, 12:1 compression ratio, DOHC, 16 valves, fuel injection, digital ignition, electric starting 140 kw (187 hp) @ 9,500 rpm; 147.1 kw (200 ps)(197 hp) @ 9,500 rpm with RAM air; 154 Nm (113.5 lb/ft) @ 7,500 rpm and a 6-speed transmission.
bike engines are nice, but they need to be revved up to crazy speeds to make much useful power. That's not too much of a problem on a bike as weight is very low, but a car is far heavier, wouldn't make things very sluggish at lower RPMs?
Although, I suppose, with this kind of swap, you wouldn't want to drive at low RPMs ever!
#16 | |
Chode
Anyway, a turbo would help along with racing filters and the like, and maybe the transmission could be modified to adjust the ratio and reduce the top speed/increase acceleration. And I would remove the yaris transmission and get a mechanical LSD and use a custom transmission (or add in an idler gear to have a 6 speed forward and reverse, 250km backwards would be awesome.... )
If you delete the cat you will need a mil elim,since the ecu cannot be reflashed to turn the rear 02 circut off(yet). A mil elim is a malfunction indicator lamp eliminator. Its baisicly a resistor that tells your ecu that it is getting a clean reading ,it is pluged into the rear o2 harness.
#18 | |
der Zeck
| DIY: Installing Greddy TI-C Exhaust System | redyaris | DIY / Maintenance / Service | 13 | 08-01-2009 04:05 AM |
| FS/FT: Toyota Borla Performance Exhaust System | nevermorez | Items for Sale by private party | 16 | 06-01-2007 09:36 PM |
| Non cat exhaust CEL? | CASTREX | Performance Modifications | 15 | 01-28-2007 01:22 PM |
| Who have the exhaust system from Toyota (Canada)? | SimmZ | Performance Modifications | 10 | 08-18-2006 12:15 PM |
