Old 06-22-2007, 11:36 PM   #1
redyaris
Shiny Chromey Coolness
redyaris's Avatar
DIY: Installing Greddy TI-C Exhaust System
Another easy DIY. This is my first 'performance' mod. Im so psyched!!!
This DIY is for installing the awesome Greddy TI-C exhaust system available for the Yaris liftback from vendors on this site. I just happened to buy mine from NQD (thanks man!)
This DIY is mainly for people (like myself) who are a little apprehensive about mechanical stuff...ive sure learned a lot about what I am willing to do on this car because its so easy!
If youre quick it should take you no more than 1.5 hours to complete this....me, I had a beer or three while removing the stock exhaust so I leisurely completed this in 2 hours....
1. Set emergency brake. Jack the right rear of the car up using factory supplied jack or hydraulic floor jack.
2. Remove right rear wheel.
3. Note how factory stock exhaust is mounted: 2 bolts with nuts attach the exhaust to the pipe coming from the catalytic converter and engine. The exhaust hangs on 2 rubber 'grommets' near the back of the car. All these parts are very easy to reach with the tire removed.
4. Using wrench with extension break loose the factory bolt from the nuts. This took a little effort as the nuts had some rust on them (A light direct touch of WD-40 might help you remove yours easier).
5. Soak a sponge or rag with dishwashing soap and water. Apply the wet solution to the rubber grommets to assist in prying these off the exhaust mounting posts. Note the stock exhaust attaches to the grommet with a flared end. (Thanks RSHatchback for this tip!). I chose to keep the rubber grommets on the stock exhaust when I removed it because its easier to take them off after removing it.
6. Take the stock exhaust out, laugh at it and quickly discard.
7. Using a screwdriver gently pry the rubber mounting grommets off the exhaust mounts of the removed exhaust.
8. Greddy supplies a dome shaped flange which fits between the factory pipe and the TI-C. Put it in before mounting the Greddy.
9. Return the 2 rubber mounting grommets back onto the mounting posts on the car. This is very easy.
10. Mount the Greddy first by inserting the 2 hangers into the rubber grommets then matching up to the factory pipe with the 2 bolts and nuts. Tighten but dont overtighten making sure the compression spring becomes secure on the bolts.
11. Ensure you have enough clearance between:
your bumper and the Greddy tip (dont want any melted plastic)
The ground and your new Greddy.
If your car is lowered you're gonna have clearance problems over bumps and potholes.
12. Turn the key on and let er rip!! Man does this thing sound GREAT. Mine had the silencer already removed and I dont plan on putting it back on.
Deep deep idle tone. Great acceleration tone throughout the RPMs. Simply amazing...My Yaris no longer sounds like a sewing machine.
I hear headers and intakes also enhance the sound of the Greddy. Ill have to check those out too now I suppose!
Now excuse me I have some neighborhood Civics to harass.
Old 06-22-2007, 11:39 PM   #2
redyaris
redyaris's Avatar
part 2 pics...part 3 pics coming tomorrow...i ran out of daylight.
Old 06-22-2007, 11:48 PM   #3
nqd
Drives: 07 Yaris LB Absolute RED
hey! that used to be mine! haha nice to know that u like it... enjoy!
nqd is offline   Reply With Quote
Old 06-23-2007, 01:13 AM   #4
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Hope that this will be available to sedan owners like me!
ricepower is offline   Reply With Quote
Old 06-23-2007, 04:46 AM   #5
Jerkratt
Jerkratt's Avatar
question the megan header came with a flange thingy... do i use the greddy one when i finally get it in the mail... or the megan one... i ordered a strut bar and exhaust from the invision dealer on here and has not gotten back to me yet... and i pm'ed him my order still says pending....
"It hurts more when its wet"
Old 06-23-2007, 05:41 AM   #6
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Talking about two different ends of the car.
With the Megan Header, you use the donut between the Header and the collector (as shown installed in my Megan DIY), and you have the choice of using Megans supplied gasket, or reuse your stock gasket between the cylinder head, and header.
The donut for where the two exhaust pipes meet for an axle back, is a stock part, and can be reused with all the aftermarket systems so far.
Old 06-23-2007, 06:00 AM   #7
Jerkratt
Jerkratt's Avatar
ooooooooo i thought it was a catback lol sorry ether way ok thanks answered my question
Old 06-23-2007, 06:27 AM   #8
Chris07LB
Chris07LB's Avatar
REDYARIS - wanna sell that tip?
Old 06-23-2007, 08:58 AM   #9
redyaris
redyaris's Avatar
Yes sir....it got a little bit of undercoat overspray on it...no biggie. Ill PM you Chris.
Old 06-23-2007, 09:04 AM   #10
redyaris
redyaris's Avatar
part 3 pics
Old 07-12-2007, 07:00 PM   #11
Kaeon
Drives: 2007 Yaris Hatch
Hmm it looks weird...
Kaeon is offline   Reply With Quote
Old 06-25-2009, 06:14 AM   #12
RyanRedYaris
RyanRedYaris's Avatar
Drives: 2009 Yaris S Hatchback
I am planning on getting the Greddy Ti-C exhaust i have one question if i install the exhaust and than install Tanabe DF210 springs is the exhaust gonna touch/melt the bumper and would it be easy to adjust the exhaust to prevent that?
RyanRedYaris is offline   Reply With Quote
Old 06-25-2009, 10:02 AM   #13
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
I have df210's and had the greddy exhaust. Only problem I had was scraping the exhaust on speedbumps.
Greddy TiC exhaust For the Yaris Invision Yaris Sponsors Classifieds Area 17 09-07-2007 04:59 PM
INTEREST: Greddy Exhaust for SEDAN!!! C2AUTOSPL Performance Modifications 21 06-08-2007 07:07 PM
Who have the exhaust system from Toyota (Canada)? SimmZ Performance Modifications 10 08-18-2006 12:15 PM
