Old 04-04-2013, 10:20 AM   #1
dmytro_syroyizhka
Drives: Toyota Yaris Black 2007
Rubbing problems
I just got 16x7 40+ offset rims with 185/55/16 tires. I got pretty bad rubbing in the front fenders. I am getting them rolled but one of the clips holding the top part of the fender ripped out. Will that effect it? Dissapointed i dont fit well. might wanna trade with someone for some 15 inch rims n tires
dmytro_syroyizhka is offline   Reply With Quote
Old 04-04-2013, 10:28 AM   #2
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Pretty sure that fender liner should be tucked INSIDE the fender and not sticking out like that.
I have 205/50/16 and I don't rub that bad.
Black_griffin6 is offline   Reply With Quote
Old 04-04-2013, 11:04 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Cut the portion of the liner not secured and remove it
185/55/16 is a pretty meaty tire same size as stock but a larger diameter so another 25.4 mm larger rolling diameter than stock
Old 04-04-2013, 12:39 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Yeah should have went with a 50 instead of 55
Old 04-04-2013, 01:28 PM   #5
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
nice rims though...
B2FiNiTY is offline   Reply With Quote
Old 04-04-2013, 01:33 PM   #6
1.5
Form>Function
1.5's Avatar
For 16x6-9 195/40 or 195/45 are my fav but its a harsher ride with less ground clearance
Old 04-04-2013, 01:38 PM   #7
dmytro_syroyizhka
oh the fender liner should be tucked in? thanks man. I got this car handed over from my bro who bought it for cheap salvaged. But yeah too late for diff tires man. Just gotta roll them
Old 04-04-2013, 01:57 PM   #8
Black_griffin6
Yeah man, the fender liner goes inside the fender.
I made that same mistake and I was wondering "How come my tires are rubbing so bad?" XD
Try tucking the liner back behind the fender and see if your rubber isn't as bad.
Old 04-04-2013, 02:03 PM   #9
1.5
Form>Function
1.5's Avatar
You probably will not have a fender lip to snap the liner back into if youre going to roll them though
Old 04-05-2013, 09:54 AM   #10
dmytro_syroyizhka
will that be a good thing tho?
Old 04-05-2013, 03:35 PM   #11
dmytro_syroyizhka
took off my fender liner no rub what so ever. But i heard taking thins off is dangerous. Correct?
Old 04-06-2013, 02:02 PM   #12
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
correct! when liner removed road debris will be able to get into engine compartment.
if you look in engine compartment you'll be able to see tire through the gap between fender and fender apron
OTA'sTOY is offline   Reply With Quote
Old 04-06-2013, 02:19 PM   #13
1.5
Form>Function
1.5's Avatar
I wouldnt recommend removing the liner completely. Yes road debris will be able to get into the engine bay and will get everything very dirty and could let rocks/water in which could cause issues.
I just cut the upper portions of the liner that rubs on the tire and leave the rest especially the portion that sits inbetween the front of the tire and the engine bay.
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
Another "my tires are rubbing thread what can i do about it".... YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 12-29-2009 03:05 AM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
