Old 11-08-2011, 01:40 AM   #1
heavenswaitin
Drives: 2010 yaris
follow up on 2010 yaris problems + more problems
Hey all, yes it's me again! Still having same problems minus the stereo shorting out( so far). Dealer and complaint center said there was nothing that could be done! car still not starting half the time ,service said they still could find no problems!
Now I have another problem: the electric power steering warning light came on. I shut off the car for 10 minutes and it went off. on my way home it came on again. Please explain this. Why does this light come on? Is it in any way connected to the other problems I am having?
Thanks again for all the info you give me!
heavenswaitin is offline   Reply With Quote
Old 11-08-2011, 12:14 PM   #2
The PS light can come on for a few of reasons - Overheating of the electric PS system, sensor problem with the PS, lack of comm with the ECM, etc.
Based on your other thread and this one, it really sounds like someone needs to either replace the two dashboard harnesses or at least inspect them thoroughly for insulation damage at all mounting points of the harness. I suspect that your burning smell, radio issue, starting issue, and PS issue are all due to some harness damage.
Old 11-08-2011, 12:15 PM   #3
heavenswaitin
Drives: 2010 yaris
I am looking in to that. I am just afraid of whats going to happen if I continue to drive it,and since I have no other vehicle then I have no choice!
what causes this warning light?
Old 11-08-2011, 12:18 PM   #4
heavenswaitin
Drives: 2010 yaris
They keep telling me there is no problems with this car. Does any one know how long the lemon law take to replace the vehicle?
Old 11-09-2011, 08:18 AM   #5
heavenswaitin
Drives: 2010 yaris
another problem last night
last night my yaris just quit! would not start, crank over or anything! I had it towed to the dealer. I was stranded! The reason I bought the car was to avoid this. Not very happy this morning! Now I wake up and see the recalls on the news about the crankshaft and power steering but yaris is not on the list. Could this be why my eps light came on?
Old 11-09-2011, 08:22 AM   #6
Definitely not - The recall for the PS issue is for vehicles with hydraulic PS. The Yaris has electric PS.
Old 11-09-2011, 08:54 AM   #7
heavenswaitin
Drives: 2010 yaris
ok thanks wasn't sure on that one! so what would make my car not even crank over? Sorry about all the questions they probably are really stupid but at least I am learning ( very slowly)
Old 11-09-2011, 09:09 AM   #8
There could be many causes - Low battery, blown fuse, damaged wiring, problem with the ECM, etc.
Did the cluster light up, but there was no response when you turned the key? If that is the case, did the radio turn off while you were holding the key in the crank position?
Old 11-09-2011, 09:17 AM   #9
Unless the battery died overnight, Toyota will at least now have to admit there is a definite problem with your vehicle.
Old 11-09-2011, 01:16 PM   #10
heavenswaitin
Drives: 2010 yaris
12:00 and they still dont know anything except the tow driver left the key on and ran the battery dead. not happy
Old 11-09-2011, 01:31 PM   #11
While it's in the shop, they should be able to tell you why the PS light came on, as the PS ECU will have a logged a DTC that they can read with the Toyota TechStream tool.
Old 11-09-2011, 02:14 PM   #12
heavenswaitin
Drives: 2010 yaris
ok I so did not even understand any of that except ps= power steering, so my ps has some kind of chip that showed a code that was registered? Am I even close? If not hope I brought a smile or 2! No shaking of the head! Jeez I am completely car stupid!
Old 11-09-2011, 02:36 PM   #13
Most of us are familiar with P???? codes associated with a check engine light. These can be read by anyone with an OBD II reader.
There are other systems on the car which are monitored and therefor trouble codes are logged whenever there is a failure. However, these systems are proprietary and can only be retrieved by a Toyota tech using what is known as TechStream tool.
Old 11-09-2011, 04:25 PM   #14
heavenswaitin
Drives: 2010 yaris
they said starter shorted out or something like that
Old 09-02-2013, 09:09 PM   #15
afthabfadul
Drives: yaris 2008
Dear technician techn,my car is yaris 2008 front right speed sensor disconected. Sensor wire blue and red another another tow wire colour pink and violate ido know witch wire is conect please replay .
afthabfadul is offline   Reply With Quote
Old 09-03-2013, 03:40 PM   #16
afthabfadul
Drives: yaris 2008
Old 09-03-2013, 03:47 PM   #17
A correct replacement sensor should have the mating connector to the connector of the pink and violet wires. Can you post a picture of what you have?
Brand New 2010 Yaris 5 door automatic, <200 miles, MPG 127.0.0.1 Fuel Economy Forum 12 09-07-2019 09:11 PM
2010 Yaris Stereo Install Help FPG In Car Entertainment + Electronics (audio / video / alarm) 13 04-21-2012 09:16 PM
