Old 05-21-2013, 01:15 PM   #1
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Exclamation aem EMS-4 standalone ECU
Hi guys, next step in my project is running a standalone ecu (currently using aem FI/c). I would like to use the aem EMS, but I am not sure of some compatibilities with my 1NZFE...
Sensors that I know EMS will support/run easely (correct if Im wrong);
1.Mag crank sensor (already work with FIC, why not)
2.Mag cam sensor (already work with FIC, why not)
3. 370cc deatschwerks injector, 12.2ohm high impedance so why not.
4.Coolant temp, I will use aem unit...
5.Air temp, I will use aem unit...
6.Throttle position sensor (already work with FIC, why not)
Sensors that I am not sure to be able to run;
1.My oem 1nzfe ''coil on top''??
2.My idle air control valve with 3wires on the TB??
3.Could I just use my aem wideband O2 sensor or I still need the original one?
4.Knocksensor??
Also there is 2 kind of wiring kit you can buy, first is a small one with no relay, second is a big one with relay & fuses... Which one I would need? Probably the big one since I dont know how I could still use the stock fuse/relay box.
Thanks big time, and I know most of you guys run Yaris, so you may not answer my question about the idle air control valve (TB is dif from echo)... But thanks for help anyways!
maxthehax is offline   Reply With Quote
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
Standalone ECU d1nzfe Performance Modifications 11 12-24-2009 11:46 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
