#1 |
![]() ![]() Drives: 1NZ-FE Join Date: Oct 2008
Standalone ECU
Anyone on standalone ecu?
What is the setup? Do u still leave the stock ecu for controls of air-con and fan? Is there any plug and play harness for 1nzfe? |
Cali Yaris has a standalone ecu
#3 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Don't know what fan do you mean? dash or radiator fan? Radiator fan must be connected with the ecu aswell |
#4 |
![]() Drives: 07 Yaris RS 3dr Join Date: May 2009
Most stand alones will run the dash and fans, ac ect... but not many can control the drive by wire TB..
#5 | |
any reviews from you on your ecu yet? |
#6 |
I'm running AEM EMS.
It runs radiator fans, electric water pump, water/meth injection and all engine parameters. Also, have a 2-step rev limiter with anti-lag set up. My A/C is out and I'm on cable so it doesn't manage those things.
#7 |
Until I am confident that this ecu works great I will not post any reviews just yet. Although there is a good probability this one works fine.
Although If you have any questions on mine just ask! BTW why do you need a standalone ecu? Tell us some info on you mate! |
#8 |
hello dave :)
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#9 |
![]() ![]() Drives: Yaris & Supra Join Date: Nov 2008
MoTeC anyone? ;)
#10 |
![]() ![]() Drives: Vios Join Date: Oct 2008
Apexi PowerFC available for NCP91
http://www.brashboy.net/superchager/main.html |
#11 | |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
| DIY: Tricking ECU Throttle Body Relearning | gwasabi | DIY / Maintenance / Service | 2 | 04-03-2009 07:02 PM |
| Yaris has a learning ecu? | YogiYaris | Performance Modifications | 9 | 05-30-2007 07:03 PM |
