![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Uneven wear after rear spacers
For once, I have a problem that isn't engine/forced induction related
![]() I installed 10mm Penguin Garage rear spacers a little over a month ago. Recently I noticed an unusual wear pattern on my rear tires. I have an idea of what the problem is (and it really isn't a big deal if so), but I'd appreciate some feedback. Wheel/tire spec: 15x7 +37 Oz Superleggera with 205/50/15 Yokohama S Drives. Pretty sure I installed the spacers correctly, but I didn't use the four washers that were included... Mainly because I had no idea what purpose they served. Note: The wear pattern is only on the outside of the tire. Rotation is correct. ![]() ![]()
It appears that the tires are rubbing on the fender. That's my guess.
That is the tires rubbing on the fender.
The cut washers, two per side, on the lower hub bolts only, add about 1 degree of negative camber. ** And would probably solve your rubbing problem. ** Question though -- you don't hear the tires rubbing? Got that trance music pumped up?
#5 | |
#6 | |
Thanks guys. That was my thought too, except I didn't realize it until I had the OP completely ready to post lol.
Thanks for the clarification on the washers! Also, this. Quote:
lol. just to be clear, I am talking about the cut washers. The eight lock washers are used with all of the bolts.
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Rear hub spacers | Stiv | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 03-01-2010 12:54 PM |
| question on Rear Hub Spacers | mastaofdisasta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-02-2010 10:54 AM |
