Old 05-15-2013, 05:04 PM   #4
That is the tires rubbing on the fender.
The cut washers, two per side, on the lower hub bolts only, add about 1 degree of negative camber.
** And would probably solve your rubbing problem. **
Question though -- you don't hear the tires rubbing? Got that trance music pumped up?
Rear hub spacers Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-01-2010 11:54 AM
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 09:54 AM
