Old 11-17-2011, 08:01 PM   #1
vector9mm
Drives: blue 08 hb
how long before replacing brakes ?
I have a 2008 hatch with about 35,000 miles of city/hiway mix. Anybody have an idea how long the brakes should last ? These will start squealing before they get to thin, won't they ?
vector9mm is offline   Reply With Quote
Old 11-17-2011, 08:15 PM   #2
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
It depends on how you drive and your use of the brakes.
Obviously more rough and repeated use of the brakes will cause them to wear faster.
Black_griffin6 is offline   Reply With Quote
Old 11-17-2011, 09:02 PM   #3
thepartsmancometh
Drives: '08 LB, '07 WRX
Our yaris sees about 75% highway usage. It currently has just under 65k miles and the brakes are still in great shape
thepartsmancometh is offline   Reply With Quote
Old 11-17-2011, 09:07 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
Please check what section you are posting in when starting a new thread. I've moved this to the correct section.
Side note- Im 106k miles and on original brakes, still fine.
Old 11-17-2011, 11:43 PM   #5
MadMax
MadMax's Avatar
With such a light vehicle, under normal driving conditions it should not be uncommon to easily get 60-70K+ miles out of a set of brakes.
And yes, modern brake pads usually have indicators built in to where they will make noise when it's time to replace them. If you're curious as to how much pad you have left, go by any tire/brake shop and they will give you an estimate based on the percentage left...
Old 11-18-2011, 12:09 AM   #6
The Limo
Rule of thumb is when the friction material is down to one millimetre thick (thickness of a dime), it is time to change the pads or shoes.
Roy
The Limo is offline   Reply With Quote
Old 11-18-2011, 05:57 PM   #7
RedRide
RedRide's Avatar
Black_griffin is correct of course.
I will add that it is not nessarily how often you use the brakes that wear them quicker but, how you uses them.
If you frequently wait until the last second to apply the brakes and then apply hard pressure on the pedal, you will ware brakes out fast.
What you have to do is gently apply the brakes sooner to gradually come to a stop without the need to apply heavy pedal pressure.
Granted, this is not alway possible but, should be practiced as often as possible. It will make them last much longer.
Old 11-18-2011, 10:01 PM   #8
poorsh2
Drives: 2008 yaris hb
just did mine with 150,000 miles. 95% highway
poorsh2 is offline   Reply With Quote
Old 07-18-2013, 12:08 PM   #9
89GLH
Drives: 2009 Yaris 4 door hatch
My 09 has 121,000 miles, changing them this weekend.
89GLH is offline   Reply With Quote
Old 07-18-2013, 01:10 PM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im at 110,000 km still on original but need replacement next summer..
Old 07-18-2013, 01:48 PM   #11
kou
Drives: 08 lb
102,000 miles still had some pads left but rotors were warped and rusty so I upgraded to corolla calipers and pads and bigger rotors.
Old 07-18-2013, 03:59 PM   #12
nookandcrannycar
This ^^^^^. My brakes were only 20% worn at 207k+ miles. Trini's brakes lasted 400k miles. Some people wear out their brakes in under 100k miles. IMO, a manual transmission, combined with certain driving habits helps. It also usually helps if you live in a flat area vs. an area with many hills (Houston vs. San Francisco, for example )
Old 07-18-2013, 04:08 PM   #13
nookandcrannycar
Originally Posted by RedRide View Post
What you have to do is gently apply the brakes sooner to gradually come to a stop without the need to apply heavy pedal pressure.Granted, this is not alway possible but, should be practiced as often as possible. It will make them last much longer.
This ^^^^^. I also think having a manual transmission helps re making the most of this. I hear the old 'brakes are less expensive than an engine', but I'm getting many miles out of both and I don't rev the engine very high when downshifting during this scenario.
Brakes Squealing! cmkennedy New England 1 10-30-2011 07:08 PM
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 03:20 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 04:41 AM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 01:04 AM
