Old 11-18-2011, 04:57 PM   #3
RedRide
RedRide's Avatar
Originally Posted by Black_griffin6 View Post
It depends on how you drive and your use of the brakes.
Obviously more rough and repeated use of the brakes will cause them to wear faster.
Black_griffin is correct of course.
I will add that it is not nessarily how often you use the brakes that wear them quicker but, how you uses them.
If you frequently wait until the last second to apply the brakes and then apply hard pressure on the pedal, you will ware brakes out fast.
What you have to do is gently apply the brakes sooner to gradually come to a stop without the need to apply heavy pedal pressure.
Granted, this is not alway possible but, should be practiced as often as possible. It will make them last much longer.
Brakes Squealing! cmkennedy New England 1 10-30-2011 06:08 PM
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 02:20 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
