![]() Drives: 09 hatchback Join Date: Dec 2008
You can't go wrong
2009 with 187k miles. Looks like new. Regular oil changes, one new battery, one trans fluid and coolant change and a new set of tires (dealer Bridgestone were good for 150k miles!) That's it!! Just got back from brake check. No need for new pads. Still using original pads. Still getting 40 mpg!!
#2 | |
#3 | |
I still have my original brakes at almost 282k miles. I just had my brakes checked in February....many more miles of life left. IIRC, my pads were under 40% worn at 208k miles (actual figure is on Kal-El's mileage thread). Yarisworld member trini_per4mance (an original owner who has more than 500k miles on his Yaris) didn't have to do any brake work at all on his Yaris until 400k miles.
Highway miles don't need ally of brake.
Re my Yaris, my miles are a good mixture of highway and surface streets with signals or stop signs. I think the main reason in my case is that I drive my Yaris pretty gently. With Trini (judging from his previous You Tube videos), I think you're right. He doesn't drive gently, but drove a ton of highway miles when he was racking up the miles quickly on his Yaris.
4 years of P90X!
if you hypermile you hardly ever use brakes. just sayin.
![]() ![]() ![]() Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
It is amazing how long Toyota Yaris parts can go before needing replacement.
Yeah, my driving style is somewhat that of a hypermiler, but my maintenance gaps re some things (spark plugs, oil changes, air filter changes, etc) and ignoring others (throttle body, MAF, etc.) probably keep me from getting consistent 'hypermiler results'.
Just remembered I replaced air filter once (cleaned old one a few times) and yeah its ben mostly highway miles. But up and down California coast and meandering the Sierras is full of braking. The mechanics at the shop were also shocked at the original brakes.
Hypermiling rules! |
| Is it wrong to max out a Steering? | dante2086 | DIY / Maintenance / Service | 13 | 09-17-2010 03:56 PM |
| Wrong Fitment Yaris | Kaotic Lazagna | California | 2 | 08-04-2009 02:12 AM |
| Whats wrong with Rota's? | mastaofdisasta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 172 | 05-22-2009 12:13 PM |
| Will this work or I got the wrong harness? | TDL | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-19-2007 03:26 PM |
