Old 09-16-2010, 05:42 AM   #1
dante2086
Drives: Toyota Yaris 07
Is it wrong to max out a Steering?
I have a question. Is it wrong to max out a steering wheel, that is to say, turning it till it stops, I am very curious about it.
dante2086 is offline   Reply With Quote
Old 09-16-2010, 06:45 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
on hydraulic, yes. on electro-servo, no, not really.
Old 09-16-2010, 08:53 AM   #3
bankrobber
Drives: 2007 Yaris Hatchback
I try not to. Wont that put a little strain on CV joint
Old 09-16-2010, 10:01 AM   #4
RedRide
RedRide's Avatar
Just to clarify........
In a hydralic sys, hydralic pressure is at its max when the wheel it turns all the way to one side. Any weak area in the lines could rupture and that is why it's not a good idea to do so.... at least holding it there for any prolonged period. Briefly is usually just fine.
An electric sys obviously does not have this problem.
Old 09-16-2010, 10:37 AM   #5
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
So does this mean it's ok to do on the Yaris?
I've done it my share of times making tight turns.
teddy is offline   Reply With Quote
Old 09-16-2010, 12:09 PM   #6
as long as you don't slam the wheel to its stopped position like a gorilla too often, should be all right?
Old 09-17-2010, 08:02 AM   #7
dante2086
What's an electro-servo system, and is that what yaris uses?
Old 09-17-2010, 08:29 AM   #8
yep, an electric motor to assist with the steering, not a hydraulic pump system like on older cars.
Old 09-17-2010, 10:12 AM   #9
BLH
Drives: 2007 Yaris Sedan
My 2007 has the electric motor for steering and the operators manual warns not to hold it at the full rotation for long periods of time. If you do the motor may overheat and the steering ECU may temporarily turn off the power steering.
Old 09-17-2010, 10:18 AM   #10
well there you go, straight answer from Toyota :)
Old 09-17-2010, 11:16 AM   #11
RedRide
RedRide's Avatar
The key phrase here is "long periods" whatever that means"
In normal parking "full rotation" will not be held for "long periods".
Toytoa is evidenty advising an over abundence of caution.
Even if the thermal sensor does cut out, no permanent damge will be done.
They are simply explaing why, under extreme conditions, the PS may cut out temporarily.
Old 09-17-2010, 01:20 PM   #12
bankrobber
Correct but when doing reverse donuts you may hold at full lock for longer periods of time
Old 09-17-2010, 01:45 PM   #13
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
^ ROTFLMAO
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 09-17-2010, 02:56 PM   #14
exactly what I was thinking. LOL
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
