Old 09-17-2010, 11:16 AM   #10
RedRide
RedRide's Avatar
Originally Posted by BLH View Post
My 2007 has the electric motor for steering and the operators manual warns not to hold it at the full rotation for long periods of time. If you do the motor may overheat and the steering ECU may temporarily turn off the power steering.
The key phrase here is "long periods" whatever that means"
In normal parking "full rotation" will not be held for "long periods".
Toytoa is evidenty advising an over abundence of caution.
Even if the thermal sensor does cut out, no permanent damge will be done.
They are simply explaing why, under extreme conditions, the PS may cut out temporarily.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
