Old 02-16-2012, 06:09 PM   #1
momo-yx
Drives: yaris yx
little problem
little help plz
I want to replace fuel filter , but how I can pull it out .
momo-yx is offline   Reply With Quote
Old 02-16-2012, 09:23 PM   #2
To get to the filter (which is just a little plastic mesh device pictured below) you have to disconnect the hoses from the fuel tank cover, unscrew it (there is a special tool for it, but I used a piece of hard wood and a plastic mallet to turn it).
Once you get the cover off, you pull out the fuel sender, pull the fuel pump out of the sender and pop the filter off.
Old 02-17-2012, 06:54 AM   #3
momo-yx
Drives: yaris yx
means
you open it by turning it this way
Old 02-17-2012, 07:56 AM   #4
Originally Posted by momo-yx View Post
means
Yes. It is like unscrewing the cap on a bottle.
Old 02-17-2012, 07:07 AM   #5
bronsin
bronsin's Avatar
The FF isnt part of any scheduled maintenance.
Why do you want to change it?
Old 02-17-2012, 08:19 AM   #6
momo-yx
Drives: yaris yx
At first start after half a day or more , the car Struggling
to start. (only first start)
seems like the fuel does not reach to the engine very well.
Old 02-17-2012, 08:27 AM   #7
momo-yx
Drives: yaris yx
CTScott u the boss
thanx
Old 02-19-2012, 10:37 AM   #8
menz
Drives: yairs blue 2007 automatic 1.3
While you are on it, check the fuel in the tank, if it looks like it is dirty or something, get out of the tank. I had to do it because the fuel here is horrible at some places. I had to change the filter and the car now is great. Just an advice hope you can use it.
menz is offline   Reply With Quote
Old 05-16-2013, 02:26 PM   #9
sansag13
Drives: 2009
Thank you CTScott for detail explaination.. However it would be really helpful if you can explain how to clean the filter or if it cannot then what is the replacement part# to be ordered.
sansag13 is offline   Reply With Quote
Old 05-16-2013, 03:00 PM   #10
The filter is not really cleanable with its design. The mesh screen at the bottom can be cleaned though by blowing it out with compressed air.
Toyota only sells the filter (the round can part) as an assembly that costs about $160: 77024-52180
You can purchase an aftermarket filter for about $30 (Beck Arnley 0433008)
Old 11-14-2013, 09:54 PM   #11
franmora84
Drives: Yaris HB
help, I cant put the ring back, it seems to to screw in
franmora84 is offline   Reply With Quote
Old 11-14-2013, 10:25 PM   #12
The threads are very coarse, so it looks like it is going on crooked until you complete the first turn.
Old 11-19-2013, 11:05 PM   #13
Sedan
Drives: '08 Manual Yaris Sedan
My two cents to this.
I got my fuel pump inspected at the dealer earlier this year. They removed the entire fuel tank from the under side of the vehicle and then removed the above assy with a special tool.
One more thing.
Before removing the pump, it would be best to check fuel pressure to see if there is anything wrong.
Sedan is offline   Reply With Quote
