To get to the filter (which is just a little plastic mesh device pictured below) you have to disconnect the hoses from the fuel tank cover, unscrew it (there is a special tool for it, but I used a piece of hard wood and a plastic mallet to turn it).
Once you get the cover off, you pull out the fuel sender, pull the fuel pump out of the sender and pop the filter off. Fuel - Sender.jpg Fuel - Filter.jpg
