![]() ![]() Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
very notchey temp dial
I had to take apart my dials to trim some of the plastic away bc I bought smd led for my interior. Well I got my dials back together but the temp gauge has a notch half way through cold, right in The middle of cold/hot and half way through hot. What did I do wrong?
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
#2 | |
Yes.
OK. the gear train is off. If you turn it at all while it is apart that occurs. You will have to pull it back apart again and experiment with it. I haven't messed on up in a while, but I don't recall there being alignment marks, so it's a bit of a hassle to get it back right. After the first time that I did that I learned to mark the gears when I took one apart.
Thanks scott, im pretty mechanically inclined myself but I could not for the life of me figure out why the dial was notchey. I took it apart and put it back together a few times and now the notch is gone, weird! The dial had full range and motion just notchey. Everything is good now though thanks.
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Inlet air temp vs. vehicle speed | LtNoogie | Performance Modifications | 8 | 04-27-2009 12:20 AM |
| Tach Installed & Temp Wheels On | justjesus | Off-topic / Other Cars / Everything else Discussions | 4 | 02-07-2009 01:26 AM |
| outside temp on cluster??? | ae92trueno7 | Cosmetic Modifications (Exterior/Interior) | 11 | 01-01-2009 10:36 PM |
| Auto dim mirror with compass and temp | Violin | Cosmetic Modifications (Exterior/Interior) | 7 | 08-30-2006 06:48 PM |
