Old 12-31-2008, 09:38 PM   #1
ae92trueno7
ae92trueno7's Avatar
Drives: 2007 Yaris Supercharged
outside temp on cluster???
hey guys... just wondering if any of ur yaris have an outside temp reading on ur clusters???? i notice on the top right hand corner of our odometer reading
there is digital numbers (not lit up) for temp reading..... and i have a temp sensor inside my bumper.... is there a special way to turn that on???
ae92trueno7 is offline   Reply With Quote
Old 12-31-2008, 10:03 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Sounds like yours has it but maybe a fuse is out...
Old 01-01-2009, 07:24 AM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Mine is the same way. I think for whatever reason the Canadian version has it disabled. I asked the dealer how to enable it, and he had no idea what I was talking about.
If anyone has any info on this I would appreciate a response as well, since I want to get this working too.
devinlamothe is offline   Reply With Quote
Old 01-01-2009, 07:51 AM   #4
Toyota uses the same LCD display for a LOT of cars, many of them having the temperature function, but I don't think the Yaris' electronics supports it. Although, the higher trim levels of the Vios (aka Yaris sedan) here do have that functionality...
Old 01-01-2009, 03:03 PM   #5
Franck_Qc
Franck_Qc's Avatar
Drives: 2008 Yaris RS
At your dealer you can have a rearview mirror that gives you the outside
temperature.
I have one:
Formerly 2008 Yaris RS Liftback 5 doors:
http://smg.photobucket.com/albums/v26/diofra/Yaris/
Now 2010 Matrix XR
http://smg.photobucket.com/albums/v2...2010%20Matrix/
Franck_Qc is offline   Reply With Quote
Old 01-01-2009, 03:18 PM   #6
andries
aka Jack Wolfskin
Send a message via MSN to andries
I have it stock in my Yaris , and it works very well
Look here ( not my car but I have the same Gauge cluster)
andries is offline   Reply With Quote
Old 01-01-2009, 03:37 PM   #7
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
This Yaris pictured above has a lot more than just external temperature reading, it has a start-stop button, digital climate control, and probably steering wheel mounted audio controls as well.
Ultra high spec!
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 01-01-2009, 03:52 PM   #8
andries
aka Jack Wolfskin
Ultra high spec!
Yeh, exactly. I have that all except the start stop button en digital AC (it's manual on mine)and many more like brake discs rear, nine airbags, stock lowering, stock 17" rims, audio with six speakers, traction control, verhicle stabilitie control etc,etc
Old 01-01-2009, 04:01 PM   #9
andries
aka Jack Wolfskin
is it not possible that the dealer can switch it on through the OBDII port?
For example; the light and sound when you not fasten you seatbelts is also to swich of through the OBDII port!
Old 01-01-2009, 05:33 PM   #10
Treyz
~ ambient one ~
Treyz's Avatar
thats one of the reasons i wanted someone o get a picture of the pcb board of the instrument cluster to see the connections and possibly the jumper settings. i believe that its the same electronics for all trims just not enabled. this is a trick that a lot of car companies use to get you to pay extra while all they have to do is flip a switch. think OEM fog lights all Yarii are already pre wired for them and its only a matter of gtting the right relay.
It's a hit or miss with certain vehicles on whether they are prewired or not. I've owned cars that were and weren't.
As for the fog lights. I wired up my aftermarket DLAA's so that they light up in my cluster. Went to Toyota and picked up the relay. Before the hack, there was a whole DIY on how to do it.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 01-01-2009, 06:09 PM   #11
Treyz
~ ambient one ~
Treyz's Avatar
its still there its called USDM EUSES (or something like that) install. i got the relay from ebay was a scion branded (but it;s the same as LExus and TOyota) and it cost me 14$ instead of the 70$ from the stealership.
Wow .. I payed under $20 (tax included) for mine and think it was a Denzo from the dealer. They're really ripping you off over there huh, lol. Oh and I also shopped around the dealers too and never heard a price like that for it.
AMBIENTLIFESTYLE
Micro Image
Old 01-01-2009, 11:36 PM   #12
Burningbjorn
Burningbjorn's Avatar
Drives: Toyota Yaris 1.3 vvt-i Cool
I have it in my 1.3L yaris!
look @ the right side! it say's 21c
Burningbjorn is offline   Reply With Quote
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 11:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 10:53 AM
Instrument Cluster Stoln General Yaris / Vitz Discussion 2 06-23-2007 02:43 AM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 12:37 PM
Auto dim mirror with compass and temp Violin Cosmetic Modifications (Exterior/Interior) 7 08-30-2006 07:48 PM
