Old 01-23-2007, 09:37 AM   #1
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Exclamation CLUSTER LIGHTS WENT OUT
The cluster lights (tach, speed, o etc area.)
I started my car this morning let it warm up 10 or so mins.
Got in turned on my head lights and when I put the car in reverse to leave the drive way BAM there went the cluster lights on the dash.
I thought WTH..
I reached down on the left side dash area where the dimmer switch is for the cluster lights and it was all the way up (full bright) I turned the dial down past the notch grabbing part where it starts the dimming process for going dimmer and dimmer too off and it came back on.. I turn the dimmer all the way down and its dark and start the dimmer up and it gets brighter and brighter but when I go past that notch bump area for full brightness it goes out again.. Any one had this problem????
Go4th is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-16-2007 12:00 AM
Shift knobs with lights? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 0 09-20-2006 05:09 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-03-2006 12:38 AM
