![]() Drives: 2007 toyota yaris Join Date: Mar 2014
Vibrating 2007 Toyota yaris, 113,000 Miles HELP!!
Ok so i have a 2007 toyota yaris and has 113,000 miles on it! Today the "check engine" light came on, I checked my gas cap and it was loose so I tightened it on and light was still present. I then disconnected (waited 15 minutes) and reconnected the battery. (negative first when disconnecting and negative last when reconnecting) and now My car vibrates when i am not driving or have my foot on the gas pedal. I am really worried about this, I am reading it can be the motor mount damaged and I also read that since that the battery was disconnected that the car's system needs to relearn itself and that by driving so it can relearn its system and the vibration will go away? is this true? any other helpful device? I have driven it much today.
Thanks in advance. |
You need to clean the throttle body now. Carbon deposits build up on the throttle body over time and when you disconnect the battery the zero point gets reset, and the carbon deposits are enough to allow enough air to enter to make the idle rough. If you did nothing it would self calibrate after a couple of weeks, but cleaning the throttle body will resolve it quickly.
It self calibrated after a day or so. I was about to clean the throttle body too.
| 500,000 miles on my Yaris. | trini_per4mance | General Yaris / Vitz Discussion | 133 | 04-10-2021 02:22 AM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
