Old 05-29-2013, 09:48 PM   #1
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
500,000 miles on my Yaris.
So I finally hit 500,000 miles on my Yaris on Sunday 26th May @ 9.24pm. The car still runs perfect. Absolutely no issues with it whatsoever except with my clutch. I change out my original clutch after 400,000 miles and installed an ACT 4 puck ceramic disc with a heavy duty p/plate. After one year of running the car, I starting having shifting issues. Initially I thought the slave cylinder was giving up and after replacing it and still having the same issues, I thought the p/plate gave out, so I went ahead and bought another ACT 4 puck ceramic disc and a heavy duty p/plate.But when I dropped the gearbox, I realized that it wasn't the disc or the p/plate, but the flywheel. It was worn down a lot and the disc wasn't barely grabbing onto it. And because I couldn't afford any downtime, I installed the 2nd new ACT clutch kit with the worn flywheel. The clutch bites but not at fast as it should at high rpms. So I can't shift fast when I'm running out my rpm. I need to replace the flywheel and install a carbon/kevlar disc and heavy duty p/plate. Oh, and my water pump pulley is so badly worn from the the back of the belt running on it, that it actually has a groove in the pulley and is cutting that new belt that I recently installed. So I already have the new pulley to swap out.
Parts that are still working properly:
1. All Sensors (Oxygen, Crank, Cam, Knock, Coolant Temp, Oil Press)
2. A/C Compressor
3. Electric Power Steering
4. Fuel Pump & Injectors
5. Ignition Coils
6. Radiator
7. Brake Booster, Master & Slave Cylinder, Rotors and Drums
8. Throttle Body
9. Engine
10. Manual Transmission
Here's a list of repairs that I've done on my Yaris so far:
1. Struts & Shocks @ 153,000 miles on 9/7/08
2. Alternator @ 323,000 miles on 4/15/09
3. F&R Brake Pads and Shoes ONLY @ 400,000 miles on 2/21/10 (First and ONLY brake job)
4. Driver's Side Rear Hub Assembly @ 435,000 miles on 2/19/11
5. Clutch @ 448,000 miles on 9/3/11 (First clutch job)
6. Backup Switch @ 448,000 miles on 9/8/11
7. Sway Bar End Links @ 451,000 miles on 11/2/11
8. Passenger's Side Rear Hub Assembly @ 457,000 miles on 1/13/12
9. Oxygen Sensors @ 459,000 miles on 2/8/12
10. Alternator @ 467,000 miles on 5/26/12
11. Clutch Slave Cylinder @ 468,000 miles on 6/14/12 (Didn't need replacing. It was the flywheel that was worn)
12. Starter @ 469,000 miles on 6/25/12
13. Clutch @ 474,000 miles on 9/2/12
14. Fan Motor @ 479,000 miles on 10/2/12
15. Fuel Filter @ 481,000 miles on 10/30/12
16. Driver's Side CV Axle @ 483,000 miles on 12/1/12
17. Fuel Pressure Regulator @ 492,000 on 3/22/13
18. Valve Cover Gasket @ 492,000 on 3/27/13
19. Water Pump & Pulley @ 502,000 on 6/18/13
20. Clutch @ 506,000 miles on 8/11/13
21. Shocks & Springs @ 515,000 on 11/23/13
List of Acessories & Mods:
1. SUS Custom 2.5" Air Intake Kit
2. eBay Exhaust Headers
3. Magnaflow Catback Exhaust System
4. Weapon-R iThrottle Controller (Best investment ever!!!)
5. Rims (From 15" to 16" to 17" and now 18")
6. Tanabe Lowering Springs (With 500k miles on them)
7. Scangauge II
8. HID's & LED's
9. Double OEM Spoiler & Lip Combo
10. Eliminated Cats
11. Magnaflow 28" Resonator
12. 1ZZ Throttle Body
13. Taylor Helix Throttle Body Spacer
14. Tein Lowering Springs
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 05-29-2013, 10:15 PM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Alright!
Glad to see a fully intact Yaris hit 500K, that's badass.
I'm @ 530ish, but with a second motor swap and one trans swap since I'm going turbo any day now and wanted a fresh start.
-Type 07 FFL-
My odometer 03/11
Old 05-29-2013, 10:31 PM   #3
nookandcrannycar
:respek t:
Congratulations! Just yesterday, a new member replied to a post I made about changing my oil at 240,010 miles inspired him and that he won't worry anymore about putting too many miles on his Yaris. I replied that you (what you have done) = my inspiration. I don't have the mechanical skills you do to do my own fixes once 'replacement becomes more frequent' (so to speak), but documenting 'what at what mileage interval' as you have helped me decide how long I want to keep my Yaris (probably until almost 400k----and will get another one if the French don't 'muck it up'). I'm at 245,704 miles and there are at least 4 original owners between us -- Contraband831 was at 246,000 when I was at 244,400 and another is at 265,000+ and 2 more are at 350,000+. Among original owners, I think I can safely say that no Yarisworld member will ever catch you. Again, Congratulations!
Old 05-29-2013, 10:47 PM   #4
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
Thats amazing!
Part car, part owner...takes two to tango to achieve that type of mileage.
Well done sir!
I'm the Prez at my house...in fact I cruise around in YarForce One!
When I'm not driving my Yaris, I'm doing this:
http://gogogordy1.wix.com/scooter-aficionado
Gogogordy is offline   Reply With Quote
Old 05-29-2013, 10:53 PM   #5
Perpetuous_Dreamer
Drives: Yaris 2007
Congratulations! Do you plan to keep your car or looking for a new ride?
Perpetuous_Dreamer is offline   Reply With Quote
Old 05-29-2013, 11:30 PM   #6
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Oh this inspires me so much.
I'm so glad I decided on the Yaris!
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-29-2013, 11:36 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
Amazing! Really glad to see this car is still on the road, and really makes me optimistic about my Yaris. Haven't put a single mile on it in nearly 6 months, so it may take me longer to hit 500k (currently at about 128k).
Old 05-29-2013, 11:38 PM   #8
Congrats Trini. Amazing job you're doing. I'm a long way away from 500k being at only 92k.
Old 05-30-2013, 12:23 AM   #9
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Wow! over 200 miles per day.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 05-30-2013, 06:14 AM   #10
bronsin
bronsin's Avatar
Only 1038 miles from last October till now.
At that rate I'll get to 500,000 when Voyager 1 gets to Alpha Centauri.
Old 05-30-2013, 07:25 AM   #11
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
This is epic I must say
Ryze268 is offline   Reply With Quote
Old 05-30-2013, 10:07 AM   #12
NEexpat
Drives: 2009, auto, 4dr LB
OK, so what you're saying is the Yaris really starts falling apart at 450'000 miles.........j/k
Congrats!
NEexpat is offline   Reply With Quote
Old 05-30-2013, 10:52 AM   #13
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i like this... now we know approximately how long ours might last... thanks
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-30-2013, 11:55 AM   #14
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
I'm half way there, glad to see this bad boy still running strong!
Old 05-30-2013, 11:56 AM   #15
bronsin
bronsin's Avatar
Unfortunately 500,0000 miles over 7 years doesnt translate into 200,000 miles over 15 years.
The 200,000 mile/15 year car wouldnt do as well....
Still...who can say theyve owned a car with 500k on it?
Old 05-30-2013, 11:58 AM   #16
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
YOU = Greatness
Old 05-30-2013, 12:10 PM   #17
UberSilver
UberSilver's Avatar
I put 1/2 million on my 85 Toyota 4x4 PU.
Old 05-30-2013, 01:47 PM   #18
RABYARIS
RABYARIS's Avatar
Drives: 2009 Yaris 3D AT
Awesome...keep going...
'09 AT, CC, PW, PDL, Key Less Entry, A/C, MP3, Trailer Hitch, Hard Wired Garage Door Opener
RABYARIS is offline   Reply With Quote
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Possibly purchasing a Yaris, how many miles do you go without major repairs? chriswf New YARIS Purchase Forum 31 09-15-2012 01:14 PM
So how many miles are on your Yaris? jjonrofl General Yaris / Vitz Discussion 34 12-26-2009 12:15 AM
