Old 04-21-2014, 01:03 PM   #1
sharon2610
Drives: Toyota Yaris
Squeaky Clutch
I have a 2003 Toyota Yaris that has developed a squeak whenever I change gear. I put some WD40 on the pedal and this seemed to do the trick.....for a few days...and now it's started again. Can anyone please advise?
sharon2610 is offline   Reply With Quote
Old 04-21-2014, 01:27 PM   #2
From some past discussions on here clutch squeak seems to most often be caused by the clutch fork. Cleaning/Lubing it to eliminate the squeak is tricky because there is limited access without splitting the tranny from the engine.
Old 04-21-2014, 02:01 PM   #3
bronsin
bronsin's Avatar
In the VW Beetle service manual there were instructions (and dimensions) how and where to drill a 3mm hole in the trans so you could give the release bearing a shot of lube if it got noisy.
Seems like if you have a Yaris manual trans out of the car you could come up with something similar....
Squeaky Clutch Pedal? Kaotic Lazagna DIY / Maintenance / Service 43 05-29-2016 01:15 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Sqweek while shifting (MANUAL) dallas DIY / Maintenance / Service 43 09-01-2010 03:57 PM
squeaky clutch TickleTimeTim DIY / Maintenance / Service 4 04-28-2009 11:36 AM
squeaky clutch redimp DIY / Maintenance / Service 13 02-27-2009 09:44 PM
