Old 02-26-2009, 06:54 AM   #1
redimp
Drives: yaris 1.3 t spirit
Unhappy squeaky clutch
My 03 t spirit has developed a creaky sound in the cab and a squeak in the engine when i press the clutch in. Any one know what the problem is and how to cure it.
thanks
redimp is offline   Reply With Quote
Old 02-26-2009, 07:06 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
every toyota does this
it's the pivot ball inside the trans.
pull the rubber boot off where the clutch arm goes in, and put a little grease on the pivot ball
Old 02-26-2009, 10:04 AM   #3
redimp
thank you, i will try that!
Old 02-26-2009, 10:59 AM   #4
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
that white grease stuff works well i think, I can't remember what it's called
Old 02-26-2009, 02:30 PM   #5
Yaribhini
Lithium grease?
Yaribhini is offline   Reply With Quote
Old 02-26-2009, 02:47 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
actually, lithium grease drys out quicker than say wheel bearing grease
Old 02-26-2009, 09:56 PM   #7
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I have to check this to!!! When I press my clutch I can hear it outside of the car!!! Not even a 1977 Bettle I had that sound...
I Drive a 129whp Yaris ;)
Old 02-26-2009, 10:08 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
every toyota i've ever owned has done this.. funny stuff
Old 02-26-2009, 10:21 PM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
It's actually not a ball, but a short rod (less than an inch long) with rounded ends. It look like a small ball because you can only see one end. Anyway, the slave cylinder puts pressure on the clutch arm via this rod, and the end contacting the arm does indeed get dry. The Tacoma forum crew recommends a quick shot of PBR blaster right into the socket of the every oil change. I guess it's it super easy to spray into there with the straw (sort of like a WD-40 can, only bigger) and thickens up so it stays in place...
Old 02-26-2009, 10:26 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
here's what it looks like
and when you're spraying....
..............just keep it off the clutch disc......
Old 02-26-2009, 10:28 PM   #11
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
this happened to me. wd40 fixed it. but u have to b careful not to get any on the clutch or u will get slippage
Old 02-27-2009, 05:22 PM   #12
PetersRedYaris
Hmmm, apparently we are talking about different pivot points. I am talking about the rod between the slave cylinder and the arm which also can be the cause of a squeeky clutch.
Old 02-27-2009, 05:26 PM   #13
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Yeah, my old girlfriend had a squeaky clutch... oh wait... we're talking about cars.
Old 02-27-2009, 09:44 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
ahh
usually that's not the one that squeaks, that i've found.. it's the pivot point INSIDE the trans
07 clutch burning? driver or design? kennywhy DIY / Maintenance / Service 22 10-01-2009 01:03 AM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
Street/Race Clutch dngz Performance Modifications 10 06-23-2007 12:05 PM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
