![]() Drives: 02 vitz rs Join Date: Feb 2014
need help. engine making ticking/lifter noise
engine 1nz-fe... oil. 10w-30... serviced every 3 mths
but i've noticed that i'm getting noise from the lifters but only when i'm in traffic or after long drives. ![]() car doesn't hesitate or stall or any of the weird stuff, the crap gas we have causes it it pink which is really bloody annoying but that's about it. any ideas? thanks in advance
so many pedestrians..... so little time
toyota
could be your water pump..check inside the pulley if you got pink stuff leaking.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
thanks marcus... thats the next on list to change
Lifter noise is normal for our engine. It becomes more audible as the oil gets hot and loses its viscosity. Running a higher viscosity oil would likely help, but would then cost you a bit of fuel economy.
#5 | |
thanks ctscott
Did I mention I'm also smelling Gear Oil periodically??
| Making a engine wiring harness | maxthehax | Forced Induction Forum | 14 | 06-02-2013 09:53 AM |
| Whining noise from engine bay when under load. | rasper | General Yaris / Vitz Discussion | 2 | 05-07-2011 06:46 PM |
| car making cheap car noise | the_boss | Cosmetic Modifications (Exterior/Interior) | 5 | 03-07-2011 08:05 AM |
| Helicopter noise from the engine??? | jonr0613 | DIY / Maintenance / Service | 10 | 07-16-2009 06:56 AM |
| engine noise?? | poshi | General Yaris / Vitz Discussion | 23 | 09-04-2006 10:45 PM |
