Old 08-01-2006, 09:57 AM   #1
poshi
Drives: Yaris 3 Dr
engine noise??
hello everyone..
anyone have this problem? my yaris... everytime when i shut down engine and walk away from my car, i can hear the "dit-dit-dit" noise from my engine or somewhere under the hood.. it stays there for quite a while..sounds like something is turning and hitting something and after a while it stopped... anyone have similar problem? my car is about 2.5 wks old and about 2000km ODO now..... i hear this since the first week...
poshi is offline   Reply With Quote
Old 08-01-2006, 09:59 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Nothing to worrie about.. its the metals cooling down.. thats what I was always told.
Old 08-01-2006, 10:01 AM   #3
PixieDawn
Drives: Yaris 2007, Eclipse 2000
I remeber when I picked up my yaris there was this sticker on the glove box..saying something about after the car is turned off it tests the gas tank for leaks or something and you would hear a noise..
I will see if I can find the sticker when I get home from work
PixieDawn is offline   Reply With Quote
Old 08-01-2006, 12:48 PM   #4
Henshin
a go-go!
Henshin's Avatar
Drives: Silver 07 HB - 5spd
ditto
Henshin is offline   Reply With Quote
Old 08-01-2006, 01:33 PM   #5
oktaren
Drives: 07yarisliftback04aveohatchback
my cars have always done this, but i haven't heard the yaris do it yet...weird.
oktaren is offline   Reply With Quote
Old 08-01-2006, 01:37 PM   #6
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Ive had that noise before on exhaust manifold shrouds and electric cooling fans continuing to run after the engine is off or if the temp is ok the fan slowing down.
mikeukrainetz is offline   Reply With Quote
Old 08-01-2006, 05:57 PM   #7
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Usually it is the exhaust cooling down. It is normal.
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 08-01-2006, 06:30 PM   #8
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Originally Posted by poshi
hello everyone..
Th popping kind of noise I have been told is the oil dripping back down in the oil pan. I am a diesel mechanic and we hear it all the time, and it can also be the metals parts cooling down as stated in another post.
Old 08-01-2006, 06:33 PM   #9
rstb88
rstb88's Avatar
Drives: Silver Hatchback
and i think the gas tank thing only happens 5hrs after it has been sitting there. and ya its either the oil dripping into the pan or cooling metal. I hear a weird noise when I'm in reverse, like a heatshield is loose and it only happens in reverse. Anyone else hear this.
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 08-01-2006, 06:45 PM   #10
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Deafness precludes me from being paranoid!
tomjasz is offline   Reply With Quote
Old 08-01-2006, 07:48 PM   #11
boxerboy
Drives: WRX ,Tacoma and Yaris
Don't worry about it. I have heard everything from bulldozers to motorcycles do it.
"PERCEPTION IS SELECTION"
boxerboy is offline   Reply With Quote
Old 08-01-2006, 08:35 PM   #12
swng
swng's Avatar
Drives: 06 3-dr auto RS
I have heard that kind of noise coming out from other cars (under similar situations) too. I believe there is no problem.
swng is offline   Reply With Quote
Old 08-02-2006, 12:07 AM   #13
Pompeii66
Drives: '08 Yaris Sedan
I'm hearing this everyday when I back out of my driveway. I thought the same thing, sounds like a heatshield or something rattling for a couple of seconds. It's only in reverse and I only notice it when it's first started up.
Pompeii66 is offline   Reply With Quote
Old 08-02-2006, 04:10 AM   #14
Dawn Eshelman
Drives: Silver Yaris Liftback
I get a "rattling" sound when I put my car in reverse. Don't have to be moving, but it also makes the sound when I'm backing up...
Dawn Eshelman is offline   Reply With Quote
Old 08-02-2006, 07:53 AM   #15
rstb88
rstb88's Avatar
ya and i have no idea what it is and its driving me nutty
Old 08-02-2006, 06:53 PM   #16
swng
swng's Avatar
Re the last two posts by Dawn Eshelman and rstb88.
I have heard the same rattling noise too. I mentioned it to the service adviser the last time I took my car to the dealership for oil change. I guess the problem did not occur there and so nothing was done. Sometimes, I still hear the same noise when I engage the reverse gear whilst stepping on the brake.
Old 08-02-2006, 06:56 PM   #17
poshi
Drives: Yaris 3 Dr
oo icic thx for everyone's input. i brought my car to the dealer and they told me the same reason too, but is there anyway i can avoid that? it is not bothering but it is just weird that it doesn't happen to my other cars
Old 08-03-2006, 09:29 AM   #18
abattle
second noise possibility...
I have heard this noise on two different cars in the past, both toyota...one was an older corolla(1990/1999) and the other was a 95 camry... both were the motor mounts going bad. When in reverse the motor mount lets the engine rub against the mount and causes vibration on the car and if it gets bad you can feel it in the steering wheel. But these are newer cars so I would hope that is not the problem but might be worth checking out. I can tell you how I found it on the cars, if you care to know just ask...thanks,abattle
abattle is offline   Reply With Quote
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
