![]() Drives: Toyota Yaris Join Date: Apr 2014
Servicing..
Okay, I'm a little puzzled. I've called to make an appointment for my Yaris this weekend. I was under the assumption that a tune up included belts and wiring. But now I'm being told something completely different. Is this normal to occur?
Sent from my iPhone using Tapatalk |
the yaris does not have a distributor.. so no wires to change.
drive belt (alternator & AC are 1 belt) are not due, if it doesn't show signs of cracking (rubber dry rot) spark plugs on the 1nz are usually iridium plugs and can last like 80k miles. |
Thanks. Because I became sfrustrated quickly. Felt like I was getting the run around. I'm at 102,000 miles now. And I was told that my shock absorber is missing from my glove box.
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
a shock absorber missing from your glove box?
LOL the glove box have a strut kinda thing that makes it open up slowly.. instead of slamming down.
This tends to be lost, or forgotten to be put back when changing the air filter. It doesn't really matter if you don't mind how your glove box don't open like an Audi. |
😱 ... So now they may charge me for it!!! Smh.
We don't go in for a "tune up" like we used to back in the 80's. If you've kept up with the maintenance schedule... There is nothing much to get checked.
Oh. So I'm thinking too far back in time. I feel so embarrassed. That's right, I did buy a compact car. Smh. 😅
#10 | |
. I wonder what Toyota's official name is for that part ?....and for that matter the 'shock absorbers' for the hatch ?
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
According to the maintenance schedule what is needed at 100,000 miles is
1. Change coolant 2. Change engine oil and filter 3. Reset oil replacement reminder 4. Rotate tires 5. Visually inspect brake linings/drums and brake pads/discs Roy |
The shock is called a stopper http://www.yarisworld.com/forums/showthread.php?t=5158
Oh okay. Thanks. I called Toyota about it and I was told that it's covered under my warranty. So hopefully, it will get fixed or replaced under that.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Yes, there's no such thing as a "tune up" anymore, on any car.
Only things to consider is changing the serpentine belt if you haven't yet. A coolant flush. As for the spark plugs, I changed mine somewhere around $120K and they came out with little wear. Up to you how preventative you want to be. I do minimal maintenance because really that's all the Yaris needs. 163,000 miles and I've only done the above 3 items + tires and one battery change. Oil changes every 5K. Only one repair being a rear wheel bearing. Everything else is original, even brakes and struts. |
#15 |
Wow..Thanks a lot everyone..You folks have been a lifesaver big time..
| Servicing and knocking noise ? | mpepper | UK | 0 | 05-19-2011 08:04 AM |
| Window crank on the floor after toyota servicing | IMAMEX | DIY / Maintenance / Service | 5 | 05-08-2011 03:02 PM |
| car shaking after servicing | Canadian | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 11-25-2008 06:40 PM |
| 10000 km servicing | firez3r0 | Australia | 27 | 09-29-2007 10:30 AM |
| Cost of first servicing | Island Boy | DIY / Maintenance / Service | 14 | 05-20-2006 08:21 PM |
