![]() Drives: Toyota Yaris 5 door hatch Join Date: Sep 2012
Fan Blower Only Working On 4 FIX!!!
This will be a short DIY on how to replace your blown resistor on your Yaris, so that your fan works on all 4 speeds, not just 4!
Things you will need 1. Yaris ![]() 2. Philips screwdriver(a short one with a medium head) 3. 1* 87138 52030 (blower resistor part number) about $20 from Toyota ![]() First locate your fan blower motor(mine was at the passenger side foot well) Next move your attention toward the firewall or FRONT of the car. (The resistor sits about where you would imagine your right big toe would be if you were sitting in the seat )![]() You will see a black connector with 4 wires coming out the bottom of it(mines colours were black, green, white and blue) Push the connectors pin in and pull on the connector until it comes out(not the wires )![]() Locate the 2 screws that hold the resistor to the housing. Take a SHORT philips screwdriver(no you cant use a long one as there is not much space) Rotate the screws anti-clockwise(looking at them from the bottom) until they come out ![]() Get your new blower resistor and insert it the same way the old one came out. Reinsert the 2 screws(make sure that they are tight as the last thing you want is for the resistor to vibrate around and for the air from the blower system to escape from around the resistor, you will also see a sponge around the resistor for insulation) Plug the connector back into place And Bobs your uncle
There are no Yaris drivers, only Yaris LOVERS
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
does it look like this? :) sadly your images don't show.
Hi jcboy looks very similar.
If you right click on the image and click on the "open image in new tab" you should be able to see it:) sorry man :)
| Blower motor officially not working | waydizzy | DIY / Maintenance / Service | 14 | 11-25-2023 05:41 AM |
| A/c & heater fan not working | b_hickman11 | DIY / Maintenance / Service | 15 | 01-05-2016 04:09 PM |
| AC Blower Motor / Fan Does Not Turn on Period | dyslexicanaboko | DIY / Maintenance / Service | 7 | 01-30-2012 11:59 PM |
| Blower fan question | daf62757 | General Yaris / Vitz Discussion | 6 | 08-16-2011 07:27 PM |
| Why wont my fan blower work? | lucy7509 | DIY / Maintenance / Service | 4 | 08-09-2011 03:48 AM |
