Old 08-03-2011, 06:38 PM   #1
lucy7509
Drives: 2002 Yaris
Smile Why wont my fan blower work?
Hello
I have already replaced the blower relay and the 40amp fuse for the blower fan yet it still does not work, previously on occassion, when on the motor way the blower would just start up, but this had not happened now for the last week.
I can not find a service manual for the car, as it is a diesel. 2002 Yaris
Any hints, otherwise, I will have to succumb to taking it to the garage, and pay out a fortune I dont have.
Thanks
Lucy7509
lucy7509 is offline   Reply With Quote
Old 08-03-2011, 11:48 PM   #2
Do you have access to a multimeter? It could be the switch, the blower resistor, or the motor itself.
Old 08-07-2011, 11:38 PM   #3
victorddr
Drives: 07 Yaris CE
Check for corroded ground connection. Check for voltage drop between wires, if you found more than 0.2v within wires, replace the wire.
victorddr is offline   Reply With Quote
Old 08-09-2011, 02:42 AM   #4
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
Before you do anything else, try this first:
Turn on the blower and if it doesn't turn, you can try hitting the bottom part of the motor with your hand. Should be easy to reach under the dash.
Same thing happen on mine. I got a noisy blower and it just won't turn occasionally. If this solves your issue, you might need your blower cleaned or worst replaced.
Yaross is offline   Reply With Quote
Old 08-09-2011, 02:48 AM   #5
Yaross
Yaross's Avatar
oops, I just read that you have 2002 Yaris. I have 2nd generation yaris so blower location might be different.
in any case, you know where the blower is.
Does DFCO still work when using cruise control? rtom Fuel Economy Forum 10 01-20-2010 12:26 AM
Need Truth About Warranty Work . . . woof DIY / Maintenance / Service 17 12-12-2009 03:39 PM
Got hit at work today, lady drove off. Prohibit General Yaris / Vitz Discussion 41 11-04-2009 11:38 PM
Drove home from work with a damaged belt and... AznGouki DIY / Maintenance / Service 44 09-07-2009 02:08 AM
Idea I had, but I can't figure a way to make it work... kac Cosmetic Modifications (Exterior/Interior) 4 08-08-2009 09:17 PM
