Old 01-10-2010, 10:14 AM   #1
rtom
Drives: 2010 Yaris 3-door liftback MT
Does DFCO still work when using cruise control?
Seems like it would be stupid NOT to have DFCO work when using cruise control, but just thought I would ask whether anybody knows for sure. If nobody knows for sure, maybe some careful person with CC can test whether fuel efficiency drops when using CC.
I've been thinking about adding the cheap DIY CC, but there's no way I would do it if DFCO doesn't work when using CC.
rtom is offline   Reply With Quote
Old 01-10-2010, 12:59 PM   #2
deerebilt
Drives: 2008 Yaris sedan S
i know on my 08 sedan s 5 sp w/factory cruise DFCO does work
deerebilt is offline   Reply With Quote
Old 01-10-2010, 03:02 PM   #3
rtom
But are you sure DFCO is working WHEN the CC is on?
Again, seems like it should, but I thought I would like to be sure before deciding on the DIY CC.
Old 01-10-2010, 03:30 PM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Works on my 2009 with AT & factory CC.
Old 01-10-2010, 05:09 PM   #5
127.0.0.1
ya it will if you are on a sufficient downslope
Old 01-10-2010, 06:25 PM   #6
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
Maybe a dumb question, but how can you tell?
TwoBearWisconsin is offline   Reply With Quote
Old 01-10-2010, 07:17 PM   #7
advocate
Drives: car
An MPG reading device will display 9999 MPG during DFCO. That's the easiest way to tell if it's working or not.
Old 01-10-2010, 09:32 PM   #8
deerebilt
you can also feel and hear when dfco shuts fuel off and turns back on.. and yes does workd with cc engage.. scangauge also reads 9999 mpg when fuel shuts off like posted above.
Old 01-11-2010, 03:32 PM   #9
Yaris Hilton
Smile
Like the man said, you can feel the fuel cut off.
Old 01-19-2010, 10:24 PM   #10
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
If you go down a steep enough hill, the CC will let off the gas all the way in an attempt to not go over your set speed. This is when DFCO will occur.
Reddog99 is offline   Reply With Quote
Old 01-20-2010, 12:26 AM   #11
Yaris Hilton
Smile
It cuts off the fuel way before that, like 500-700 milliseconds after you release the throttle pedal. (Figure from the manual.) The ECU downshifts the transmission when you're picking up speed downhill and touch the brake, which is the big increase in drag you feel.
Some of you are making way too much of this DFCO. It's a piddly thing, found on most cars nowadays. Just another emissions reduction device.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Cruise Control Transplant 2009->2007 LB WolfWings In Car Entertainment + Electronics (audio / video / alarm) 7 11-29-2009 01:13 AM
CRUISE CONTROL HELP!! MGargano DIY / Maintenance / Service 1 05-13-2009 08:22 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
