Ruler of the free world
Drives: 09 Yaris 2D HB Join Date: Jul 2010
Starter sticking or ???
Lately it seems like my starter stays engaged longer.. almost too long.
Seems like it is staying engaged even after the motor turns over.. I have found out the key does not control the amount of time the starter turns.. so I cant tell if the motor really is started before cranking stops or not ![]() Sticking starter?? ECM telling to crank too long?? Anybody ever have anything like this? Last edited by CueBall; 07-17-2013 at 03:10 PM. |
#2 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
So the force of the engine is what determines when the starter disengages?
Cuz that's exactly what it sounds like.. like the engine is forcing the starter gear out of the flywheel. But it didnt do this before.. I thought there was something else controling disengage.. like crank/RPM sensor ![]() What if the engine doesnt start? Perma-crank? |
Drives: 2006 Toyota Vitz RS Join Date: May 2014
Sorry to bump an old post back up..but im having the same issues with my ncp91. Did you manage to get the problem sorted?? Any ideas on possible issue?
Seemed to have worked it out!! Went to this post: http://www.yarisworld.com/forums/showthread.php?t=40811
Have tried starting car this "new" way and it seems to have worked!!! Stoked. Thought my starter motor needed a overhaul.. |
| Starting issue | birdman | DIY / Maintenance / Service | 10 | 11-28-2018 06:25 PM |
| Starter Kill | david.gartee1 | DIY / Maintenance / Service | 7 | 03-01-2014 08:14 AM |
| Remote Starter - Tail Light Problem | Chrsto4 | General Yaris / Vitz Discussion | 4 | 11-01-2009 12:36 AM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 02:30 PM |
| Starter dragging | YarisTom73 | DIY / Maintenance / Service | 5 | 08-27-2007 01:11 PM |
