Old 07-05-2011, 08:00 PM   #1
david.gartee1
Drives: 2007 Yaris HB
Question Starter Kill
I recently installed an AutoLoc keyless entry in my little Yaris with the help of DanQ's fantastic write-up and CTScott's details. Everything works perfectly, but there is another feature that is built into the system that I would like to put in that I have not figured out even after many many searches. There is a Starter Kill built in that uses a relay. The schematic shows to put the relay between the unit and the starter solenoid. I was thinking that I could use the starter wire in the ignition switch, but with two wires being used for this (called "common"), I am not sure which wire to use, or both wires, or maybe a different wire altogether? Any help would be greatly appreciated.
david.gartee1 is offline   Reply With Quote
Old 07-05-2011, 08:46 PM   #2
The starter solenoid is the small violet wire that goes to the solenoid (the cylindrical bump on the starter). You can either intercept that wire or intercept the two black wires (that go to a single pin) on the ignition switch connector. The reason why there are two "common" wires is because it is acting as a switch, intercepting a wire, so the wire gets cut and on side goes to one common and the other side to the other common.
Old 07-05-2011, 11:10 PM   #3
david.gartee1
Awesome. Thanks for all your help.
Old 02-14-2014, 03:37 PM   #4
Yaris2005og
Drives: Toyota Vitz 2005 Blue Auto
sup bro where can i find the ignition solenoid on the toyota yaris 2005 push start button
Yaris2005og is offline   Reply With Quote
Old 02-14-2014, 06:30 PM   #5
The starter solenoid is mounted to the starter. You will see the large wire going to the starter itself and then the smaller wire going to the solenoid.
Old 03-01-2014, 04:11 AM   #6
Yaris2005og
Mean shot bro CTscott
I took the start button off. I don't seem to find any big wires on it. but i saw some wires. their is a violet wire, Yellow wire, 2x White/black wires etc. Did you know which wire is the starter wire? - so i can intercept with a relay to install a starter kill?
On the passenger side on the fuse box if i'm right.. i see 2x black wires. Which wire is the starter i can cut to install a relay intercept starter killer?
Please tell me..
All i need now.
Old 03-01-2014, 04:24 AM   #7
Yaris2005og
Or where is the starter motor located in the toyota yaris 2005? So it can be easier for me to find the big wire to intercept
Old 03-01-2014, 07:14 AM   #8
The starter is on the front of the engine, just below the alternator.
autoloc, keyless, starter
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
Starter problem wormley DIY / Maintenance / Service 2 10-29-2008 09:56 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
