![]() ![]() Drives: 09 Yaris Hatchback Join Date: Oct 2014
Aftermarket Cams
Who makes aftermarket cams for 09 Yaris? I've been through a few websites but still cant find a company who makes them.
Jun
Jun is overpriced, but I can get them. Much easier to do a regrind locally.
How much power do you want to make? stock head should be good for 250hp. An lsd would be a better investment.
#6 | |
My kit has a T28 but I may want to go with a T3 if it fits |
Ptuning.com can make you a nice bottom end if that's what you want. The sleeves on the 1nzfe are thick the motor will hold 300hp as they are. The head flows very well as it is maybe a little port and polish. It's all your own choice just some advice also you have to factor if you get cams to raise the redline power is coming in later as will boost unless you get a smaller turbo. I personally like to keep as much torque down low as possible because I am never really going past 100mph and 10-11psi at 1/3 throttle in any gear makes for some fun times. sorry for the rant.
![]() Drives: 2008's Black Yaris RS Join Date: Sep 2009
I heard Gude camshaft is good for 1nz....anyone use?
Gude's reputation is questionalble.. There was a big thread on that one
#10 | |
That's all I did to my head and made a reliable 350 whp with stock cams, stock valves, just valve springs. Ptuning does great work; good, professional shop.
| Can an aftermarket part void my car warranty? | KCALB SIRAY | General Yaris / Vitz Discussion | 7 | 05-26-2022 10:47 AM |
| OEM vs Aftermarket Water Pump? | antone | DIY / Maintenance / Service | 0 | 10-23-2012 12:25 PM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 06:50 PM |
| Aftermarket Parts Interest? | Fluid Motorsports | General Yaris / Vitz Discussion | 27 | 11-09-2008 12:00 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
