Old 10-23-2012, 12:25 PM   #1
antone
Drives: 2007 Yaris
Arrow OEM vs Aftermarket Water Pump?
Hi,
I've searched thru most of the water pump threads and found some great info and DIY.
Anyhow by the looks of it many have had to replace there's if not more than once. I tried to search for those specifically that replaced with an aftermarket pump.
My Yaris is out of warranty on original pump (07, 80k KM) I will be changing it myself but deciding whether I should stick with OEM whether the Aisin build quality has been improved or if there is a better aftermarket I heard of others using NAPA.
How has yours held up and whether it's OEM or Aftermarket (what brand)?
Appreciate it!
antone is offline   Reply With Quote
Water Pump Pulley Vioz DIY / Maintenance / Service 14 08-14-2011 04:29 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
