Old 11-10-2014, 05:09 PM   #1
BoostedTRD
Drives: 09 Yaris Hatchback
Oil Return on upper oil pan sub assembly
I found this here on the forum and I have a few questions.
how many inches from the bottom of the oil pan assembly to the desired spot for the oil return?
also what size of an fitting is the best for oil return coming out of the oil pan assembly?
My T28 turbo oil feed line came damaged and I need to replace it, Do you guys have any good places to buy oil feed and return lines?
BoostedTRD is offline   Reply With Quote
Old 11-10-2014, 05:40 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
uhh.. like this..?
Old 11-10-2014, 06:46 PM   #3
You want to drop the oil it above the oil level, rather than feeding it into the bottom of the oil pan. Where that arrow points to is just about right to be above the oil level (About 3" above the oil pan gasket). I would use a -AN type bulkhead fitting of the proper size for the turbo's output oil fitting.
JEGS and Summit Racing carry oil lines and fittings at reasonable prices.
Old 11-10-2014, 07:55 PM   #4
KTS
KTS's Avatar
Drives: Vitz RS
If I remembered I used a 9/16" bit and a 3/8 npt fitting with a 5/8" barb end.
KTS is offline   Reply With Quote
Old 11-10-2014, 08:38 PM   #5
BoostedTRD
Which one do you guys recommend? Does the oil flow better to the oil pan if it is at a certain degree? It will be 3/8 of course just using this pic as a reference.
Old 11-10-2014, 09:04 PM   #6
KTS
KTS's Avatar
Drives: Vitz RS
That is something you might have to determine for yourself. Avoid any kinks in the line to prevent oil from puddling and creating an oil flow restriction.
Old 11-10-2014, 11:23 PM   #7
With fluids and particularly viscous ones you want to avoid 90 degree turn, unless that have a wide radius, so either do the 45 or straight.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
