Old 02-26-2007, 05:17 AM   #1
007 hatch
Drives: 2007 Yaris HB US
Question metal particles in oil
Changed the oil in the wifes 07 hatchback this past weekend and when I poured the old oil back into the jug there was some very fine metal particles left in the drain pan. These particles were very fine and had it not been for the sun shining into the pan making the metal in the oil shine like a metallic paint job I probably wouldn't have noticed it all. The car has 5045 miles on it and runs like a champ. The first oil change was just short of 1000 miles and was changed with mobil1 oil and filter as was this last change.
Didn't notice these particles with the first oil change. Guess I should probably invest in one of those magnetic oil drain plugs that I saw on one of the other posts.
Is this something to be concerned with (the metal dust) or is this something that should be expected with these small 4 banger engines.
Thanks for any input.
007 hatch is offline   Reply With Quote
Old 02-26-2007, 06:40 AM   #2
bugnuts
bugnuts's Avatar
Drives: 2007 Yaris Liftback BBP
Fine dust like metal in the oil is very common with a newer car (especially a 4 cyl.) during the break-in period, a lot of it comes from the piston rings rubbing on the cylinder walls, modern engines are made with a lot tighter tolerances than older ones and are built to run at higher temperatures. Don't skimp on the oil filter, make sure you get the best available and try not to switch around your oil brands and type too much either, and just keep an eye on the dipstick. It's more than likely nothing to worry about unless the metal starts getting bigger!
"I am un chien andalusia" - Black Francis
bugnuts is offline   Reply With Quote
Old 02-26-2007, 10:59 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
A magnetic plug is always a safe play, especially on newer engines.
Old 03-04-2007, 11:44 PM   #4
PetersRedYaris
Heres why you should use a magnetic drain plug; look at how much material the oil filter missed.
Old 03-05-2007, 03:49 PM   #5
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
my volvo has two of those 'rare earth magnets' in the bottom of the pan in both the engine and tranny - I cant believe how much shit was attached to those things...
mikeukrainetz is offline   Reply With Quote
Old 03-05-2007, 09:18 PM   #6
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Where can on buy a magnet oil plug for the Yaris??? I could prolly take some of the super powerful magnet from work and just put them on the bottom of my oil pan though...they will easily smash they snot outta your finger if you get them too close.
jdubau55 is offline   Reply With Quote
Old 03-05-2007, 09:28 PM   #7
mikeukrainetz
thats whats in the pan of my volvo, nothing special, you can buy the magnetic plugs from ebay for like 5 bucks
Old 03-06-2007, 03:31 PM   #8
Lafiro
Drives: 06 Yaris Sedan
Links please, I dont know the exact name/dont know how it looks either.
Thanks
Old 03-07-2007, 09:39 AM   #9
nsmitchell
nsmitchell's Avatar
Just get some magnets from an old harddrive and attach them to your oil filter. When you change your filter, metal particles are kept inside the filter and viola, metal particles are gone. Reuse the magnets of course. Do this in conjunction with a drain plug magnet and you can't get any better.
Get YarAss in gear!
RIP - Casey Tatum
Old 06-22-2007, 02:56 AM   #10
dallas
Drives: Yaris Hatch /Landrover D2
Some of the extreme presure additives in oil are Zinc based etc, would the magnet filter out the oils extreme presure package?
dallas is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
My first oil change RogueYaris DIY / Maintenance / Service 41 02-07-2007 07:41 AM
About to do my first oil change Kaotic Lazagna DIY / Maintenance / Service 32 01-15-2007 04:00 PM
