Old 12-02-2006, 10:21 AM   #1
autophile
Drives: '07 HB Manual Yarrrrris
Help with oil change specs
Hi all,
My stupid dealer didn't get the stupid manual (or a second key) for my 2007 liftback Yaris (U.S.), so I don't know what grade of engine oil, what oil filter, or how much oil to use in an oil change.
Through reading the forums, I've found the answer to two of the three questions: Use a 2005 Echo filter, and 5W-30.
But I still haven't found the answer to how much oil in an oil change?
Any help is appreciated! Thanks,
--Rob
Yarrrrrris!
autophile is offline   Reply With Quote
Old 12-02-2006, 03:09 PM   #2
acrbill
Drives: Polar White Hatch
Did you buy the car new?
Old 01-02-2007, 11:30 PM   #3
Yaris_Fan
Yaris_Fan's Avatar
Drives: Liftback Auto
What does "dry fill" mean?
Do I need 3.9 US qts or 4.3 US qts to do an oil change?
Yaris_Fan is offline   Reply With Quote
Old 01-02-2007, 11:44 PM   #4
acrbill
I think that means if you rebuild the engine and your filling it for the first time.
You would only need 3.9 if you are doing an oil change.
Old 01-03-2007, 08:19 PM   #5
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
Should have 3 keys
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-03-2007, 09:29 PM   #6
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
You don't have to ask for an Echo filter. All the parts stores know what a Yaris is by now. Just ask for an oil filter for a 2007 Toyota Yaris, they won't look funny at you.
Racer X-8 is offline   Reply With Quote
Old 01-03-2007, 09:49 PM   #7
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
No one here knows what a yaris is. NAPA, Checker Auto., Best Buy, Etc.. Can't find oil filters or stereo install parts. This is partially why I use OEM filters.
Old 01-03-2007, 10:37 PM   #8
Racer X-8
Racer X-8's Avatar
Really? Maybe you shouldn't tell people that jk.
I just bought a filter from Advance Auto - it was an Advance Auto branded filter, because I like them, but I could have bought one of the others that were on their computer system - STP, Fram, uh, dunno - about eight different ones were listed, give or take - several...
Jeez, if they're out there, available from the filter manufacturers, why don't your stores have the ability to sell them? If they sell them in SC, why not SD?
For instance, http://www.partsamerica.com/Default.aspx get to oil filters for 2007 Toyota Yaris, a whole page full of different ones...
Old 01-03-2007, 10:42 PM   #9
eflb55
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US)
Ya I know. What I hate the most is when I walk into a Best Buy asking about install parts and they ask what car I have. I say yaris and they give me that annoying "i just sucked a sour lemon and feel pretty constipated" face.
eflb55 is offline   Reply With Quote
Old 02-26-2010, 06:51 PM   #10
micromotion
Drives: yaris...murdered
Thats because you dont have a cutty with twenty fo's on it
micromotion is offline   Reply With Quote
Old 02-26-2010, 06:56 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
do my eyes deceive me, is this another oil thread? ;)
Old 02-26-2010, 07:16 PM   #12
severous01
i dont know if that chart is wrong, or if my engine is smaller, or if i'm buying bigger bottles than everyone else but mine only takes about 3.25 q with filter change
and yes i know how to check my oil.
Old 03-11-2010, 01:56 PM   #13
TheSilkySmooth
TheSilkySmooth's Avatar
Yep, your not getting all your oil out. Using ramps? That'll mess it up. Mine usually takes 3 + 3/4 qt with a good long drain at various angles using a floor jack. Dont over fiil or it will dogg down.
Old 03-11-2010, 03:00 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
isn't the drain port at the back of the pan? therefore if you drove the car up on ramps, the oil would be more poised to exit out the now-lowered oil pan bolt..
Old 03-11-2010, 05:24 PM   #15
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
dude... they do the ramps on the rear tires in texas... you know how everything is backwards down there.
Old 03-12-2010, 12:44 PM   #16
RedRide
RedRide's Avatar
Not even NAPA dealers? They are usually the gold standard for getting accurate parts.
Old 03-13-2010, 06:41 PM   #17
TheSilkySmooth
Best filter ive used = wix 51396 - same as camry 2.4L. Best Oil = MTD 5w-30 snowthrower winter oil API SJ ( which is closer to the recommended SL on my fill cap than is SM GF4). This is for engine performance NOT validated by a used oil analysis - which itself in interpretation is oft fraught with misconcept and misconstrual.
Old 03-15-2010, 01:32 PM   #18
severous01
i'm using an alignment rack at the place i work. BMW/nissan/honda...so i know the car's level.
it doesnt really matter, when i check the stick after first turn on and shut down to check it's always on the line. and the oil is clean, just like it came out of the bottle...very little color change
but any way, it doesnt really matter. i change my oil at service interval and i'm using higher than standard oils, full synthetic so even if there's a quart left in there it's still not dead enough to change
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
when to do oil change kaymm DIY / Maintenance / Service 6 10-27-2006 11:33 PM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 10:49 AM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 09:32 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
