![]() ![]() Drives: 2007 2DR Liftback Join Date: Oct 2011
Hope these help, especially if you too go with modifying the stock speaker mounts. I used Pioneer TS-G1644R all the way around (four total; cheap, from an NYC eBay seller). In my install, no wire connector adapters were needed. Not shown is soldering the subwoofer leads to the rear speakers in my two-door 2007 liftback.
Left OEM front door speaker, with the door panel removed: Topsides of new speaker (left) vs. old front speaker (right, still in OEM mount): Ditto, except backsides: Spacer ring removed carefully by prying. Razorblade used later for cutting out the old speaker: Clipping all the supports from the back: After cutting around the edge of the speaker, cutting the original speaker-to-connector wires. Keep the wires attached to the mount long for now: Old speaker removed. Is very lightweight, but gave decent sound at least compared to the awful OEM speakers that were in my RAV 4.1s: For the fronts, I drilled three holes in the flange of the old black plastic mount (thickest part where three of the largest clipped-out support legs), and used a little Shoe Goo between the mount and the speaker's metal frame (do _not_ get it on the cone or the flexible rubber ring that attached the cone to the frame) and three of the machine screws that came with the speakers to attach them. First made sure the wires are aligned! Then I reattached the spacer ring after notching it in three places. Also used Shoe Goo, from Walmart, to attach the ring. I let the glue cure overnight, then soldered the further shortened leads. The positive and negative wires and terminals lined up nicely. Protect the cone from the solder! Completed right front speaker, reinstalled (fuzzy pic taken quickly): Right rear speaker before: New rear speaker, left: For the rear speakers, I was able to reuse the OEM mounts, but because they are smaller than the fronts I couldn't use the three small machine screws to attach the new speakers to the OEM mounts. So I used a lot more Shoe Goo, and also let them cure more than a day. The new, and also Shoe Goo'ed foam weatherstripping on the reused white trim rings make the speaker fit nicely against the now reinstalled rear panels, and they are preventing rattling of the panel against the speaker. The new speakers sound quite good, especially considering the very low cost (well under US$100 for all four). They are definitely much heavier than the OEM speakers. Their sound is crisper than the OEM's, and there's more bass. But just a little more bass is my preference: Bazooka powered subwoofer installation, http://www.yarisworld.com/forums/showthread.php?t=40420 |
2ZR swap. DO IT! Ask how!
Great photos! I'm looking at doing this in the next few weeks.
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
nice work I need new fronts ounce I get my issue fixed
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
![]() Drives: White Egg Join Date: Jul 2012
hey Lugnut,
thanks for the pic. it gave me a much clearer insight on what im getting myself into. nice job btw. i just realized how open it is in the back. lol |
Very good!
I'm sure many YarisWorld members will benefit from this! Thank you, D.
. CLA 250, 4MATIC |
#6 | |
![]() Hope they never go away, like many a website and use of similar USENET newsgroups. |
#7 | |
For the rear speakers, yes. But a couple of things: 1) the metal where the speaker mounts to is quite thin and floppy, so consider reinforcing if you'll have major bass. 2) The metal has very sharp edges, so I still have cuts that are healing from reaching behind both the old and new speakers. And look for future pics, in another thread (watch for link in my signature below), about the conversion to a two-seater! Lots of room back there too with the rear seat out. |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
nevermind, got it
Yaris beginner
Nice one thanks... This DIY is a little scary!! :D Let's see what I can do...
PS: What's that shoe goo you talk about? Glue for shoes?? :D |
Panel removal http://www.yarisworld.com/forums/sho...+panel+removal
This DIY is very interesting since you are keeping the OEM plugs. hehe
please pin this ...this is a great write up on the install..i know for those that dont want to cut supports out u can pick up speaker mounting kids cheap. Planing on doing my fronts soon.
yarisgeo13
Drives: gloss black 5 door Join Date: Sep 2013
Nice up grade for the sound system! My local Best Buy has the up grade stereo system for my 2013. I'm thinking of the up grade.
Drives: 2006 Toyota Yaris YRS 3dr Join Date: Apr 2014
Lugnut, you wouldnt have info on how to remove the rear trims to get to the speaker would you? Or would anyone else know of a thread on here with info of how to?
The rear trim panels are no fun to remove -- I had found helpful info by searching this site. Definitely pull out the rear seat before trying, and be careful so that you don't damage the plastic panels and mounting plugs. I used various plastic trim removal tools (Harbor Freight's -- both the orange and blue sets) to help pop out the individual retainers.
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| FREE ORIGINAL FRONT SPEAKER(S) + REAR SPEAKER | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-01-2014 01:55 PM |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
