Old 04-29-2015, 04:02 AM   #1
toad
toad's Avatar
Drives: street-legal go-kart
weird revs?
hey! it's been a while, but the yaris sedan and echo coupe have been doing well - until now that is...
my echo started having issues with the rpms at idle. i can't tell you how many it goes to(no rpm guage), but it gets pretty high. i don't have issues when i'm in gear(it's a manual), but anytime i'm in neutral i get higher revs. first, i cleaned the throttle body and the 'butterfly flapper valves'. i used standard carb cleaner as recommended by the auto parts store guy and it didn't really help - it was fun to work on the car, however.
went to the actual toyota dealership and $500 later and many trips back and forth it revs a little lower. they say they cleaned the idle control valve and cleaned everything else i already cleaned, but i'm still not sure it's much better. i really think they just wanted to get rid of me and my 15 year old car after numerous attempts to inspect/repair it.
anyways, they mentioned something about it possibly being the ecu after they pretty-much threw their hands up in the air, but that is costly for something even they couldn't guarantee would help($800ish). i did notice, however, the other day when i turn on the defroster it makes the idle rev higher than normal. it's weird, i can be sitting at a light or just warming up the car and when i switch the fan to 'defrost' it starts reving even higher and then lowers to it's regular higher-than-normal speed once i turn it back to normal.
any ideas? thanks and it's nice to still see some old names on here!!!!
toad is offline   Reply With Quote
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-29-2011 12:18 AM
Toyota Vitz 2006 automatic - engine revs lot thea500 General Yaris / Vitz Discussion 0 11-24-2010 03:05 PM
weird knock at full lock YRX DIY / Maintenance / Service 9 06-18-2009 11:18 PM
