Old 06-18-2009, 04:42 AM   #1
YRX
Drives: Toyota Yaris YRX
weird knock at full lock
hi guys and girls,
i have just bought a yaris 2nd hand and am loving it so far. my only concern is this weird knocking i get in the wheels when im turning at full lock. im not sure how to explain it, the best way i can explain it is like turning in a rear wheel drive with a locked diff??
it only happens during full lock any ideas?
YRX is offline   Reply With Quote
Old 06-18-2009, 07:30 AM   #2
mark schofield
Drives: 03 Echo, 04 Scion xA, 02 Range
possibly the front axle CV joints?
mark schofield is offline   Reply With Quote
Old 06-18-2009, 08:45 AM   #3
markitect
Does it feels like your tire is rubbing?
Check the plastic liner inside your fender. Mine for some reason (I think autocrossing) got warped. I just pushed on it and it popped back.
markitect is offline   Reply With Quote
Old 06-18-2009, 09:29 AM   #4
BDD
BDD's Avatar
Drives: Poor with a nice bicycle.
I'd check to see if your CV boots are torn... it's an early sign of your CV joints dying and if they're knocking already, they'll need to be replaced as soon as you can do it.... usually occurs at 80~100K miles.
BDD is offline   Reply With Quote
Old 06-18-2009, 09:43 AM   #5
Sparks Toyota-TRD
Drives: Toyota/Scion
Please check that all lug nuts are tight as well.
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 06-18-2009, 11:07 AM   #6
YRX
cool thanks for the suggestions guys and girls i will have a look tomorrow morning and let you know what it was.
hope its not CV's lol i wanna be able to fix it myself lol
Old 06-18-2009, 03:28 PM   #7
prelude
Drives: blue yaris
my car started doing the same thing it knocks when i turn full lock which i rarely do since the yaris has a good curb to curb turning ability or when i back up into my drive way i hear like something with the steering column or the axles it sounds like a thunk hard to explain
prelude is offline   Reply With Quote
Old 06-18-2009, 03:48 PM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hope its not the bearings..
Old 06-18-2009, 09:16 PM   #9
supmet
Drives: 2007 4 Door Yaris
I was always taught not to turn all the way to full lock.
Old 06-18-2009, 10:18 PM   #10
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
My Yaris is a 2008, much too new to have this kind of trouble.
However, I have eventually had this kind of symptom with almost all the front wheel drive cars I ever had (Honda, Nissan) and it's always turned out to be one or both of the CV joints.
Get it up on a hoist (not a jack unless you have proper stands - safety first!) and have a good look at the outer CV joints. Chances are that the pleated rubber boot on one or both sides will be torn.
If the problem is really longstanding, all the lube will have sprayed out, and the inside of the joint will be full of sand or dirt.
Sir A.Y. Atoyot is offline   Reply With Quote
Weird door locking problem, electrical? davembfan General Yaris / Vitz Discussion 19 09-30-2009 02:50 PM
June 13th Shannonville Full Track lapping event! Touge.ca Canada 0 06-04-2009 06:48 AM
CG Lock = next best thing to a harness schleppy Tracking, Racing, Auto-X Forum 19 04-28-2009 01:12 PM
Shannonville full track event hosted by BE - July/21/Sat Tiida Canada 2 07-06-2007 09:40 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
